Alternatives to Mobil1 15-50?
#31
things to consider
1: the 928 engine was designed in the 70's and to use 20-50 oil, unless you are in near freezing weather
2: the 928 engine REQUIRES oil with a proper level of zinc....modern Mobil one does not have enough
3: how do you drive your 928? This is by far the most important ?? If you drive on the street with only the occasional blast.....almost anything of proper weight-zinc is fine.....if you drive on track (DE, track days) then the requirements go up.....
I have had great luck with both old mobile 1 and amsoil....I will run nothing but amsoil racing in my racers....."IF" I had a street 928....I'd get a street style oil....maybe the Z rod or something else....
#33
Under the Lift
http://www.mobiloil.com/USA-English/...duct_Guide.pdf
#35
+1 Bill. My car also has 246k miles and I also only use M1 15W-50 and only change once a year or 12k miles. I also do not drive it easily AT ALL. I don't understand why so many people bunch all Mobil 1 oils together when it is clear that 15W-50 still has the correct amount of ZDDP based on Mobil 1's documentation and also verified by independent tests.
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
#36
Rennlist Site Sponsor
Actually...
In order to help prevent early motorists from confusing gear oil and engine oil, SAE decided that they would add 40 to the actual viscosity number of the gear oil, so SAE 50 engine oil is the same viscosity as SAE 90 gear oil...
#37
Dan
'91 928GT S/C
#38
#39
Chronic Tool Dropper
I stock up on the M-1 when I see it, thinking that I don't want to be stranded if federal rulemaking decides that our 'old' cars really don't need oil after all.
#40
Bob; i understand the viscosity numbers, it's just that in the day and age where all i ever see is domestics produced by the millions that all use 5-20, 5-30, or 10-30, seeing a rating that high for a plain old V8 motor is just surprising to me.
#41
As for labelling - never underestimate the inability of people to actually know what they're buying, or to pay attention to what they're picking up off the shelf.
If Gear oil were labelled 30W50 and Engine oil were labelled 20W50, a VERY high percentage of people would buy the wrong oil for their engine/gearbox. The additives package will be very different between the oils.
Heck - I recently discovered my spare reverse light bulbs on the shelf at home are for 24V
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
#42
Back in the 'good old days', air-cooled engines often seemed to like thicker oils to help with the excessive clearances needed. Harleys regularly swallowed quarts of straight 60-weight non-detergent engine oil. Early 911's started life on straight 30 weight and proceeded up from there in the hands of uninformed owners. Choosing the right oil for an air- and oil-cooled car was always a compromise; Too thin and no hot oil pressure although there was adequate flow, and too thick meant that you'd have less cooling available from the oil. Until it got too hot, too thin, and no hot oil pressure. Solution: bigger 'racing' oil pumps. Or a water-cooled V-8 in the front instead of the air-cooled six back behind the windy area.
