928 Forum 1978-1995
Sponsored by: 928 Specialists
Cold air intake Phase-1
Old Sep 29, 2012 | 08:03 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
this is the guy i used
http://www.diyautotune.com/catalog/g...tor-p-116.html
Old Sep 29, 2012 | 08:19 PM
Maleficio's Avatar
Maleficio
http://m72.photobucket.com/albumview...1.jpg.html?o=3
Old Sep 29, 2012 | 08:32 PM
17prospective buyer's Avatar
17prospective buyer
Is that seriously COP ignition?? What a build. Love your wiring harness tidyness, is that the stock harness? What is the red wrap? Firesleeve i assume?
Old Sep 29, 2012 | 08:40 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
yup, COP baby! i made the harness from scratch, mega squirt conversion etc. Firesleeve it is. love that stuff. its due to the COP and rails that i had to make the intake the way i did.
Old Sep 29, 2012 | 11:48 PM
jbrob007's Avatar
jbrob007
Very cool stuff... You should see this engine up close & personal... Had to wipe it off after I slobbered all over it The rest of the car is just as impressive!!
Old Sep 30, 2012 | 09:49 AM
Mike Frye's Avatar
Mike Frye
Craic Head
Originally Posted by Ducman82
so with the fuel rails and coils in the way of the normal side tube style air filter set up i came up with this.
My only problem is the filter housing is 4" in/out. with its placement it is hard to make (limited fab tools) a filter inlet with a 4"OD circle on one end, and fan/cone that meets the air dam.
anyone have the stock air dam/inlets they done need? or i can use to take measurement of? i seem to have lost mine in the move..
Sorry, I missed this part. I've got a spare top piece that goes over the radiator if you want to use it for measurements (one of the stock 'cones' is missing, I used it for the setup of my CAI). I'd like it back when you're done, but you're welcome to use it for measurements.
Let me know if you still want it and I'll send it along...
(I also sent you an e-mail about the other stuff)
Mike
Old Sep 30, 2012 | 11:14 AM
Lizard928's Avatar
Lizard928
Duc's build isn't actually COP, it's CNP. Very different.
My car is running COP using cayenne COP's.
Old Sep 30, 2012 | 11:18 AM
SeanR's Avatar
SeanR
Looks real sharp, well done.
Old Sep 30, 2012 | 11:38 AM
Ducman82's Avatar
Ducman82
Veteran: Air Force
COP CNP..... "close" enough.... heheheeh
thanks Sean. going to start phase II this week, a better mod.
Old Sep 30, 2012 | 12:22 PM
toofast928's Avatar
toofast928
Nice solution to getting cold air. Looks good.
Old Sep 30, 2012 | 12:52 PM
namasgt's Avatar
namasgt
That looks super nice, I wonder which method will have a better flow or denser charge. single filter like yours or a dual filter setup on each side of the engine like the CIS system ?
Old Sep 30, 2012 | 07:27 PM
928mac's Avatar
928mac
Thats the same sensor I use.
Mounted close to the throttle plate
Old Oct 2, 2012 | 10:22 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
sigh..... Phase II sucked
after tacking, the right side lifted up during welding so it smacks the hood. should have used mild steel. the stainless had some wicked "sugar" on the inside of the box.....
it will work for now so i can get the car tuned. but at this point im even thinking of using clay, make a damn mold, and try my hand at CF or FG laying.... metal is pissing me off.
Old Oct 2, 2012 | 10:39 PM
Mike Frye's Avatar
Mike Frye
Craic Head
Fiberglass or plastic would be my choice, and I think you should extend it over the radiator so you don't get the heat rising off of that.
Let me know if you want to use the stock top half of the fan shroud/intake openings to mock something up.
Old Oct 2, 2012 | 11:20 PM
jbrob007's Avatar
jbrob007
Sheet metal too thin? If it'll work for tuning then its a success You can worry about tweakin' it later. Lets get this beast on the ROAD!!!!
