928 Forum 1978-1995
Sponsored by: 928 Specialists
What HP can you expect from a unmodded S4?
Old 09-28-2012, 12:13 AM
  #31
Lizard928
Lizard928's Avatar
on an 87 auto I put down 274 rwhp with an X pipe, RMB and a pair of 300cpi cats.
Then I converted it to a manual, added camshafts (advanced to 8 deg), and put down 325rwhp on that same dyno with no other changes other than a tiny bit of tuning though the tune was still "rough"
Old 09-28-2012, 12:41 AM
  #32
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Originally Posted by GregBBRD
I personally think that is a "bit" optimistic, for an automatic, from what I've measured, but not by much.
I would think that if you got an "exceptional" engine, with everything at the "high end" of factory specifications, that might be real.
Ive thought the same..but this is a highly regarded dyno test & certification facility here in Norcal that the SCCA sends spec cars to be tuned to a HP number, and then sealed.
He has four total Dynojet units on site..its his core biz. A number of us there were kinda thrown back by it as well...but re-ran at a later date in the same range. But there is less 'tune' to set a dynojet, than other types..its just atmospheric correction at that point. Right?
Old 09-28-2012, 02:26 AM
  #33
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,476 Likes on 1,468 Posts
I'd have to agree that he should have a correctly calibrated machine. Sounds like a valid result, with that knowledge. That's actually only a couple percent more than I'd "plan" on and you had done some Sharktuning, so that makes sense. Good job!
I think that any mechanical device that is both hooked to and then has data "translated" by a computer is going to have "correction" factors that can be "altered". I've seen people claiming over 300rwhp, for these cars, in stock trim. I think everyone here knows that there is something wrong, with that.
The other thing that you will "notice" as you make more and more power, that the automatic transmissions are not "linear" in the amount of power that they consume. They become a power "black hole". The efficiency drops like a rock, after a certain point. That torque convertor just gets to the point where it can't transfer any more power from one stator to the other. The internal clutches will also stop "holding" what you are trying to feed them. Like a "slightly weak" clutch in a manual car, you really don't sense that there is all that much being lost....but when you get it to the point where it really works, the difference is huge. I had Andy's transmission in and out about 5 times, for "convertor" changes and internal transmission changes, before I was happy with it. I think I had the valve body out about 20 times, before I was satisfied...and I lost count of how many times I had the pan off to adjust things. Some of the convertors I tried were downright "funny" and got removed after a very short drive around my building.....and they were all convertors from various 928 models. The "transmission" part of this project was seriously the most difficult part of the entire job.....even more than the "oiling" problems and solutions.
I finally had to "bail" and come up with a completely different convertor.
Very time consuming, but very enlightening, also.
Old 09-28-2012, 03:28 AM
  #34
Avar928
Avar928's Avatar
What type of refreshers are to be expected to bring an engine close enough to stock without a full rebuild?
I've got 157k on my early 86. I personally think it pulls strong but to be honest, I don't know any better.
Old 09-28-2012, 07:05 AM
  #35
danglerb
danglerb's Avatar
928 doesn't have much ring or cylinder wear, so assuming good compression and leak down all that is left is AFR and details like injector having a good spray pattern etc. That is where having a MAF within spec, clean injectors that are flow matched, and no vacuum leaks maybe makes the "difference".
I don't know about the 928, but on many engines they don't make max power for maybe 30k miles as the motor loosens up.
Old 09-28-2012, 07:27 AM
  #36
AO
Supercharged
AO's Avatar
I "might" "agree" with the "statement" about the transmissions being "non-linear", but not so "sure" about the "limitations" of the torque converter to "transfer" any more "power."
Old 09-28-2012, 11:04 AM
  #37
Cosmo Kramer
Cosmo Kramer's Avatar
I wish I would have dynoed mine stock before I modded it just to see the difference. Over the one winter I did a top end refresh, plugs, wires, caps, rotors, supercharger and x pipe all at once! I saw a bit of an increase!
Old 09-28-2012, 11:27 AM
  #38
rgs944
rgs944's Avatar
Originally Posted by jcorenman
Wait a minute, aren't you the same guy who's been saying that he wasn't going to dyno his car because he didn't care about numbers?
I'm not giving you a hard time (much), and please don't dump a pile of crap all over me again. I'm just saying that your sudden interest in horsepower numbers is kind of amusing.
It doesn't matter what people "think" horsepower is, it is something that can be measured. The factory spec for the S4 (brand-new everything) was 316 bhp, that is SAE horsepower measured at the crank. If you take that number and figure 15% loss with a 5-speed that gives you around 270rwhp, and a Rogerbox with 18% loss would be around 260rwhp, that's rear-wheel hp on a chassis dyno with SAE correction. Which is pretty consistent with what's been reported here and elsewhere. So I think the factory number for the S4 is pretty good, on average. (GT's are different, but that's not what you asked).
That's for a new car. A 25-year-old car will be lower, depending on what sort of condition it is in. "Refreshing" the things that need refreshing is helpful, but doesn't add any horsepower-- it just gets you back towards where the car started. And don't overlook the MAF, it is the key component for fueling.
As for power-adders, don't believe everything that you read. Many folks report big numbers for x-pipes, but remember that they are swapping cats as well as adding the crossover. An x-pipe with new 100-cell cats (or no cats) will certainly outperform a set of melted, clogged factory cats. I do not know of anyone who has done the apples-to-apples comparison and just added the x-pipe without changing cats. I am not saying that x-pipes don't add hp, they do. But doing a proper before/after is not simple.
Will you be at Sharktoberfest? I think there is a dyno in Anaheim.
I am just looking for an average # that is close to being accurate. Did'nt mean to **** you off. lol. I was driving the other day and I let loose 11' in rears around a corner without trying. Yes it was well away from traffic. I feel I have plenty of street power I just want to get a close estimation of what that actually is. Everything I have read and learned so far tells me that with my mods I might be right around 425 crank. Plus or minus 20 does not mean a lot to me for a street car. If I was at a dyno I would probably get an accurate # but for me it is not worth the time and 200 mile round trip to do it. I am sure there is probably a dyno in Omaha but seriously I have never even heard of one in Nebraska.
Old 09-28-2012, 12:02 PM
  #39
voskian
voskian's Avatar
Back in 2000 I had my 89 S4 auto dyno'd on a Dynojet 248. Car was stock and had about 35k miles on it at the time. Showed 272 rwhp.
Old 09-28-2012, 12:27 PM
  #40
depami
depami's Avatar
I have not had my 86.5 auto on a dyno but I know it puts out 310-325 ‘cause that’s what the PO said it would do with the RMB and after market chips he installed.
  #41
SteveG
SteveG's Avatar
Jim, that's not quite what he said
HTML Code:
I likely will never dyno because I am worried about modern steet drivabilty over peak rpm range HP
I'm not sure what that sentence means. But he's coming around. Not trying to start anything. The whole dyno thing is rife with variables. Following all of this with interest. Victor has generated 3 or is it 4 threads indirectly?
Old 09-28-2012, 12:36 PM
  #42
rgs944
rgs944's Avatar
To put it simply. No, dyno #'s are not real important to me. But if someone asks what kind of power the engine has I want to be able to give them an honest and close estimation.
Old 09-28-2012, 01:02 PM
  #43
Ketchmi
Ketchmi's Avatar
"As for power-adders, don't believe everything that you read. Many folks report big numbers for x-pipes, but remember that they are swapping cats as well as adding the crossover. An x-pipe with new 100-cell cats (or no cats) will certainly outperform a set of melted, clogged factory cats. I do not know of anyone who has done the apples-to-apples comparison and just added the x-pipe without changing cats. I am not saying that x-pipes don't add hp, they do. But doing a proper before/after is not simple. "
Hey Jim....I do. Let me know if you would like to see the dyno sheets. I have hundreds from 85-86's, S4's and GTS's. I compared my crossover to Louie's and stock with and without cats, every option available including gutted factory cats. I can tell you the losses with each type of catalytic converter and cell density including the ones we had manufactured for our systems. The majority of my testing was on the same dyno, same day without even unstrapping the car. Just jacking it up and swapping while hot. No tuning was done to optimize any configuration either. When I tested against the factory cats I used the best set I had available out of at least a dozen sets unlike someone in across the pond...they started with a 240rwhp GT!
Old 09-28-2012, 01:40 PM
  #44
123
123's Avatar
http://www.dynojet.com/dyno_centers/....aspx?state=NE
Old 09-28-2012, 01:56 PM
  #45
Speedtoys
Speedtoys's Avatar
They should be as a statement of where your unknown to you tune is...
Im dynoing Sunday for insight..not for glory.
Quick Reply: What HP can you expect from a unmodded S4?
