928 Forum 1978-1995
Sponsored by: 928 Specialists
Rotrex Supercharger thread
Old 05-20-2014, 11:13 PM
  #466
victor25
victor25's Avatar
Originally Posted by Mongo
Victor, just a random thought on using the air pump as part of the air-to-air intercooling system - have you thought about using a smaller pulley on the air pump itself to drive it faster than the rate the factory has it at in order to provide more air into the intercooler?
Actually no, but its a good thought. I want to do the tests Tuomo suggested first to see what kind of difference the air pump makes versus just using the intercooler as a heat sinc. Busy with a HS graduation and a few other things, but I'll post that soon
victor25 is offline
Old 05-20-2014, 11:15 PM
  #467
victor25
victor25's Avatar
Originally Posted by Pfc. Parts
On that subject, do you recommend nikasil liners on SC engines? I know Porsche normally use these lines on their race engines, is that overkill in this application?
Just leave it stock if you can. If you can't..... might as well put bigger pistons in it. There are a few guys on here who can help with that.
victor25 is offline
Old 06-06-2014, 03:06 PM
  #468
Livio928
Livio928's Avatar
I just had a ride in a 2003 SVT 4.6ltr Mustang with a Vortech(?) SC unit and I couldn't believe how loud the chuffing sound from the relief valve was on the unit a cruising speed. Does the Rotrex chuff much? I would think this is unit is much quieter or I would have heard more about it.
Livio928 is offline
Old 06-06-2014, 03:13 PM
  #469
SeanR
SeanR's Avatar
The only time I ever hear anything that sounds odd under the hood is after having my foot in it and letting off the gas. Get a nice WHOOOOOOSH from the BOV. I'm not running the one that comes with the kit though, I wanted it to be louder.
SeanR is offline
Old 06-06-2014, 03:15 PM
  #470
Livio928
Livio928's Avatar
That sounds better. His was chuffing just cruising around! It would disappear when he would press the right foot but would come come back really loud after letting go for the accelerator pedal. It did not sound right to me since it was driving me nuts after a 5 minute drive. I think he has a problem with his set up.
Livio928 is offline
Old 06-06-2014, 04:17 PM
  #471
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,229 Likes on 1,257 Posts
Most Mustang owners do....
That does not sound normal unless he installed one of those special BOV's with the horn on it to sound louder.
hacker-pschorr is offline
Old 06-06-2014, 04:25 PM
  #472
victor25
victor25's Avatar
Hey Livio, Actually you won't even here the Wooosshh sound unless your standing in front of the car. The setup you have sends the blow off air back around to intake. So the only place you can hear that sound is through the air filter in front of the car.
BTW... when are you coming over to have that installed? How the 21st?
victor25 is offline
Old 06-09-2014, 06:20 PM
  #473
Livio928
Livio928's Avatar
Spent a couple of hours trying to do the blue hose fix. GRRRR!. Still not done. I then need to install the engine into the chassis. I am trying to work towards that date, but I can't guarantee it. I would like to have the engine running well first and I am sure that there will be some issues that need to be addressed after a 4 year hiatus and missed things/adjustments during the engine rebuild.
Work and life has been absolutely insane lately. Ask 69Guageman, since he tries really hard to rub my nose into the fact that the engine is only hours away from installation yet it moves at a snails pace. He keeps coming by in his 90 GT and never fails to mention how nice it is to drive a running 928!
I am so close I can almost taste it!
Livio928 is offline
Old 06-09-2014, 06:31 PM
  #474
SMTCapeCod
SMTCapeCod's Avatar
Originally Posted by victor25
Sorry Scott, but no it will not fit the 85/86 cars. The intake manifold and bowden assembly are in the way. the bowden can be moved, but the intake is just in the way too much. So no nothing for the 85/86 at the moment.
Are the dimensions that much different than the Murf unit?
Appears that his "S" solution was ditch the clutch fan and leave the intake/oil fill/cable assembly in place.
https://rennlist.com/forums/928-foru...s-new-car.html
SMTCapeCod is offline
Old 06-09-2014, 07:19 PM
  #475
victor25
victor25's Avatar
Even though the Rotrex unit is smaller, it sits in a completely different location than where the Murf vortex unit sits. Someday it may happen, but not yet.
victor25 is offline
Old 06-02-2015, 06:00 PM
  #476
928mac
928mac's Avatar
I am very excited to finaly have the VCB super charger on the way. Its been a long time wanting and waiting.
It sounds like Victor has brought the kit up to a level where the bugs are worked out.
I have a intercooler system with a 75mm pulley on the way. I am going to use #60 siemens injectors over the 3 hole Ford, not sure why, just am.
I am hoping the PCV system has been worked out and everything in the kit answers my questions.
The intake is off, I waiting for the kit and the Dyno date is July 8th
I CAN"T WAIT!!
928mac is offline
Old 06-02-2015, 06:02 PM
  #477
MjRocket
MjRocket's Avatar
Default Rotrex Supercharger thread
I CAN"T WAIT!!
Looking forward to seeing your Dyno numbers as I have the same kit.
MjRocket is offline
Old 06-02-2015, 06:29 PM
  #478
boomboom
boomboom's Avatar
Default I love my Rotrex
Mine is working great and only 6lbs of boost. No intercooler, just an air straightener and some upgrades with the charge tubing. Make sure to tune well and route blow off valve properly and there will be no issues.
boomboom is offline
Old 06-11-2015, 05:47 PM
  #479
Livio928
Livio928's Avatar
Where did you get your air straightener from?
Livio928 is offline
Old 06-11-2015, 06:21 PM
  #480
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
I put mine in your box..watch that space for it.
Got mine here:
http://www.treadstoneperformance.com....phtml?p=68172
Speedtoys is offline
Quick Reply: Rotrex Supercharger thread
