Is my TT finally giving up? Answer: Yes.
Under the Lift
Bill,
I used an adaptation of Dwayne's allthread method to extract the bearings, using pipe fittings rather than the wooden plug. I think this is a 2-1/2" coupling with a 2-1/2" by 3/4" reducer. Might be 2-1/4", so should probably measure the ID of the TT and OD of the coupling. It was a pretty good fit. Here's some photos
Showing starting setup (after the fact, with previously removed bearing). Once I started to push the balancer, I added the PVC section.
Showing final extraction with PVC section to catch balancer and bearings
Showing the individual parts
Under the Lift
Hi Bill, do you know anyone with a hoist. A different car on hoist, TT vertically under hoist, support outer tube on some blocks, lower hoist to press on shaft, shaft WILL begin to slide out.
Good luck
Good luck
Team Owner
FWIW be careful about the testing phase on the rear flexplate ,
what can happen is that you will seize the rear flexplate to the TC after bolts are removed,
most of the connections here are usually rusted and simply removing the bolts at the TC and thus spinning the driveshaft could possibly seize the rear flex to the TC snout .
You might consider adding a few pins to the damper on either end of it this will prevent it from sliding around,
drill a small hole and insert a rivet on either side of the damper
Under the Lift
I used a 3ft lever between the drive shaft front clamp and the end of the TT with some wooden blocks between to protect the metal. It took some force but did move, then used larger blocks of wood until the shaft had cleared two of the bearings and was able to pull the shaft out of the last bearing. This on a manual car, but I am sure the principal can be transferred.
Under the Lift
Ew....Doesn't look like I'll be fixing this today. Rear bearing carrier came apart [Correction - this is the damper carrier]. This accounts for the odd noises as parts of it bounced around on the shaft. Carriers are not avaliable separately, at least not used in good condition. So, I just ordered a rebuilt, early style (25mm with shim slot) TT, from 928 International. OUCH!
Just curious Bill. Why not rebuild with Constantine's parts?
Under the Lift
Hmmm...good point. I'm in a time crunch. I'm satisfied with the life expectancy of the stock stuff. Also, I've had good experience with the PKlamp, and I will have the option to shim the rebuilt TT I ordered, which I have done on other late model cars using the earlier TT. The rebuilt will be here Tuesday, standard UPS shipping. I definitely respect Constantine's products, but if I could have gotten a good used carrier, I would have gone that route. An early rebuilt came up next in my mind.
Also, this is largely facetious, but by the feel of the shaft (no play, quiet remaining bearing unless the factory had installed more than 2, lack of vibration), I could have removed the broken part that was flopping around and reinstalled the tube.
I don't mean just the constantine clamp but the super bearings as well.
Under the Lift
Basic Site Sponsor
Basic Site Sponsor
Ew....Doesn't look like I'll be fixing this today. Rear bearing carrier came apart. This accounts for the odd noises as parts of it bounced around on the shaft. Carriers are not avaliable separately, at least not used in good condition. So, I just ordered a rebuilt, early style (25mm with shim slot), from 928 International. OUCH!
The only downside is that all of the bearing carriers are now getting very old and the rubber, in all of them, is just as old. Don't expect the "rebuilt" tube to last as long as the original....
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
