Seat Problems... more an annoyance than anything
The seat slides forwards and backwards about 10mm with minimal force. Really annoying when you brake and the seat shifts forward just a bit.
Anyway apparently it's due to plastic guide tubes disintegrating, but as far as I'm aware the part is NLA, without buying whole new seat rails. So what have you guys done to fix it?
This seems to be a common problem, as 4 out of the 4 cars I know that have power seats suffer from this, but I can't find a solution so it left me wondering if it has something to do with our climate and that maybe the rest of the world don't have this problem?
I had some coppoer washers used for indexing the spark plugs that I never used. I just packed the gap with some of these until the sack was taken up. I called it quits when the movement was down to something less than 1mm. When refitting you have to ensure the drives on both sides are synchronised.
My current 928 has this problem but the movement is not so exagerrated [yet]. Perhaps a job for winter time when things cool off.
Regards
Fred
It's these things that wear and break.
Not found a factory replacement but one of our members has come up with a solution that I've just not had time to try out.
I used two larger tie wraps on Brads car when we discovered it on his. It reduced the slide by 8mm but it's still annoying.
Is the black thing in the middle an O-ring or a steel mounting ring of some sort?
And am I missing something about how special those plastic bits are? My local hardware stores, small and big box both, sell nylon washers and sleeves and offsets. Whether they're the proper size, I don't know. Does anybody have the relevant dimensions?
Jim's idea, above, of a razor blade and a tough hose of a proper ID and OD ought to work also.
Any chance these "plastic" bits are factory failure points for the seat mounts, engineered to fail in a crash and soak up a little impact?
Will
Will
Will
Chronic Tool Dropper
Perfect application for some Belleville washers. Else Delrin spacers to minimise the play. With anything that doesn't include spring tension, there will be play. Hose does not sound like a real solution.
