Best way to clean carpets of brake fluid
My 87 has had its brake booster replaced some time recently in its past. I know this from the beck arnley (I think) part sticker on the brake booster and the left over brake fluid in the carpet in the cabin :-(. The carpet on the firewall near the clutch pedal assembly is folded over and I will need to re-glue it after I get it cleaned.
The carpets are in really good shape otherwise. I believe they are replacements from the nap of the carpet.
What is the best way to get the carpets cleaned?
Kevin
Kevin
Team Owner
with a shop vac get some brake cleaner and spray it into the stain,
then vacuum it out,
work in a well ventilated area,
spray it suck it,
work fast the stains will come out and the carpet will be dry.
follow with a carpet shampoo
NOTE make sure the cleaner isnt flammable
then vacuum it out,
spray it suck it,
Miscible... I will look that up - but thanks.
Team Owner
the brake fluid spray works pretty well on grease stains too ,
dont let it soak as it can loosen the adhesive on the carpet
Chronic Tool Dropper
I also take stuff like that completely out of the car. Wash the carpet itself in a regular washing machine after pre-washing in a bucket with a little Liquid Tide to get as much brake fluid out as possible -before- you put it into the washing machine. Remember that brake fluid will damage paint finishes even if it does fall out of carpet vs a dribble from a bottle. Be careful!
With the carpet out, you can assess the damage done to padding and sound-deadening. Water and a shop-vac to start with, followed by detergent and water, then vacuum again to get that stuff out. Repeat until it's all clean again. Let it dry COMPLETELY before putting stuff back in. You may want to restore damaged paint if the fluid has been soaking in for a while. I the sound deadening is soaked, your only real choice is replacement; you just can't get it all out of the rubber junk.
I would remove carpet, discard sound deadening/padding, saturate carpet with Dawn dish soap and scrub with brush, hose down with high pressure wand at car wash. Continue hosing until rinse is clear of soap. Repeat as required. Vacuum up as much water as possible and let air dry before reinstalling. The sound deadening/padding cannot be cleaned of the brake fluid and must be replaced.
Brake clean might discolor the carpet. I would start with alcohol. it is pretty much non toxic and cheap. You can flood on a lot of alcohol and not do any damage.
I have a Bisel - it is useless on the house carpet but I put in some Zep carpet cleaner in it full strength and it seems to work great on Porsche carpet. Some closed cell foam would make a great replacement for the padding.
When I put in the brake booster I used some windshield sealer between the chassis and the booster. Even if the brake master is leaking the fluid should not come inside the car.
Under the Lift
Also, brake cleaner formulations include acetone (Gunk is up to 40% acetone), which might dissolve some of the glues and backing material that hold the carpet together.
