928 Forum 1978-1995
Sponsored by: 928 Specialists
G8RB8's 928S4 Resurrection Thread
Old 08-24-2012, 12:59 AM
  #61
G8RB8
G8RB8's Avatar
Originally Posted by depami
Why pull it? Drop the cross member and pan and have a better look first.
Be careful, you'll be doing good to get back half of every dollar you spend.
Point one It's being done in a shop by pros with all the right tools so little to be gained. With the end play out of spec I'm going to do the crank and rod bearings anyway. No brainer for me.
Point two Gulf Performance has the client base in 928s to make it a break even plus proposition at least which is OK by me. Anyway for now that's off the table.
Old 08-24-2012, 01:30 AM
  #62
jcorenman
jcorenman's Avatar
Originally Posted by G8RB8
.9 I think ...
".9" what? Millimeters? Inches?
If you mean crankshaft end-play of 0.9 mm, then that's trouble-- max spec is 0.4 mm. But I would expect shiny bits in the filter, which you are not seeing.
If you meant 9 thousands (0.009") then that is within spec.
You're talking lots of discretionary dollars here, you want to be sure.
Old 08-24-2012, 01:33 AM
  #63
G8RB8
G8RB8's Avatar
Millimeters
Old 08-24-2012, 01:43 AM
  #64
G8RB8
G8RB8's Avatar
You are correct but every cent spent on this is discretionary, otherwise I would have bought a KIA.
Old 08-24-2012, 03:37 AM
  #65
Bill Ball
Under the Lift
Bill Ball's Avatar
Millimeters
Yeah, that's way out of spec (>0.4mm). You MAY have escaped damage. I saw one 928 with obvious, symptomatic thrust bearing failure and it measured 1.65mm. Fortunately my engine at 245K miles is still 0.2mm.
Yes, you need to pull the motor and make sure the thrust bearing has not spun and cracked the block.
Old 08-24-2012, 08:36 AM
  #66
G8RB8
G8RB8's Avatar
Motor's coming out. Rods, mains, seals (main and cams), tb (known good wp), pan gasket (silicone), fuel lines. What else? Let the expert opinions fly.
Old 08-24-2012, 04:38 PM
  #67
killav
killav's Avatar
I have owned my car for six years now. I wish I would have started a master thread like this back then detailing EVERY repair I have done to my car. It would be hundreds of pages now LOL. There is just so much little stuff that gets forgotten.
It would be great to be able to point to a master thread when selling the car as proof of "hey look at all the blood, sweat, and tears I have in this thing". I have done all of the work either by myself or with friends. And I just haven't done a good job of saving all the reciepts (on purpse haha).
Old 08-24-2012, 04:44 PM
  #68
G8RB8
G8RB8's Avatar
Default Mats Came in Today
Funny light makes the trunk mat lettering look lighter. It's not.
Old 08-24-2012, 04:51 PM
  #69
G8RB8
G8RB8's Avatar
Default Shift **** Too
Not sure I like it.
Old 08-24-2012, 04:54 PM
  #70
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,728 Likes on 1,327 Posts
Rings, ultrasonic cleanout of the lifters, R&R the head oil galley plugs and clean the galleys, R&R the rear cam plug seals with pins (if not already done), consider R&R'ing the timing chain pads. Cam/oil pump/crank gears good?
Old 08-24-2012, 05:06 PM
  #71
docmirror
Shameful Thread Killer
docmirror's Avatar
Deburr the lower gallery of the block, install a windage tray, setup for additional crank case vent and air/oil separator, Shave and flow the intake runners, match weigh the recip masses,,,, I could go on, and on, and on. If only someone had advised checking the TBF results before paying. If only....
Old 08-24-2012, 05:15 PM
  #72
G8RB8
G8RB8's Avatar
PO did the top end pretty well. I'll put off going through it till I get this done. $$ I can do the top myself. We'll be looking closely at the oil pump, but unless it's ingested a bunch of metal it should be OK. I wasn't aware of the cam plug issue. I'll research it. Thanks
  #73
928mac
928mac's Avatar
Jim you should be ok.
When I did mine it must have moved a 100 thou which is major.
I pulled the cross member against most everyone’s advice and they were right.
The bottom of the engine comes off like a 2 stroke engine which leaves the crank hanging from the rods.
More importantly, the bearings were showing some brass on the thrust bearing but nothing was damaged.
I have heard that if it touches the block then its to late.
I got my bearings from roger. they came in Porsche boxes and were very affordable.
here is the link
http://forums.pelicanparts.com/porsc...ngine-car.html
Brad
Old 08-24-2012, 05:20 PM
  #74
G8RB8
G8RB8's Avatar
I just factored it in and figured if it was good it would be gravy. So, no gravy. I'm not disappointed at all.
That's all good stuff, but it wasn't factored in, so not this round.
Old 08-24-2012, 05:26 PM
  #75
andy-gts
andy-gts's Avatar
Looks like you plannned ahead and are doing things right. Nice car! keep the post going, I should do this also
Quick Reply: G8RB8's 928S4 Resurrection Thread
