Alignment shop refused to drive my car onto the ramp with sensors attached.
Try an NTB, one by my house does excellent work, had the Z done yesterday and they spent the time needed to get it spot on (around 2.5 hours) and it is a bit tricky due to the suspension and rear wheel steering. PLUS, they have it where you can get realigned as many times as you want within the next 12 months!
Administrator - "Tyson"
Well, you CAN jack the car, as long as it is PULLED back down to the original ride height. So, car on lift, measure ride height in front, jack car, calibrate and whatever, put car back down on the slip plates, pull the front suspension down via the swaybar until it settles at the original ride height, align wheels. We did this once and it worked out just fine.
Mk
Under the Lift
Er, that makes no sense to me. If you pull it down while on slip plates so the ride height is exactly the same as before you raised the car, how does that result in not the same geometry? Porsche has no problem with that.
So I called the same shop up that refused to drive the car to calibrate the sensors, I talked to another guy who I assume has actually used the machine. They do just roll the car back and forth about six inches to calibrate it. My car is aligned now.
The only pitfall is the technician didn't set my caster correctly. Instead of lowering both sides to be in the range of 3 to 4 degrees. He just raised the right side up to 6.5 degrees to match the left side, so both have positive caster, just way above the factory specifications. I know this won't wear my tires, but it will create changes in camber during turning that aren't correct. I have the print out of the alignment.
Should I go down there and complain, enjoy the car and its perfect handling as is, or just find another shop to align the car in a month or two? I have a stripped bolt on the cradle holding the front control arm on. So I need to helicoil it soon. I hope I can do it without removing bolt bolts and leaving the arm in place to preserve the currently alignment.
I'd enjoy it and maybe get it re-aligned after it settles for a couple of months. The helicoil concerns me. I'd do that pronto.
