Well I bought one Project Gt
New/Guy/New/Owner. I ended up buying a 89 gt project. Not sure what I was thinking, but its mine now.
Serious need of paint.
blower motor bad.
guessing the air compressors bad also.
super slop shifter.
no dash lights.
That's it for now!!!
I should have know better after owning a 80 Euro s years ago.
Let the fun begin.
Mark
blower motor bad.
super slop shifter.
no dash lights.
Let the fun begin.
Mark
Talk to Roger about his shift linkage setup. Replacing the front ball is a pain and not necessary with his setup. Blower motor might be a resistor pack instead. If so it will still work on defrost.
You have to use torch fire or a strong heat gun to melt the locktite off before you can undo that allen bolt. Most will try to undo the bolt without melting the locktite off and end up damaging the bolt, which leads to having to cut the part out and buying a new one.
Ali
Ali
shifter slop can really RUIN a 928.....don't ask me how I know....
The good news is its just a series of bushings that are fairly easy fixes......the most typical problems are the bushings in the lever itself & the rear coupler bushings.....get the solid delrin version from Roger....that should improve things quite a bit......there also is some great short shifters out there..but I haven't tried any myself
What color is the car? If its single-stage Guards Red, it can be amazingly resurrected with a cut and polish (I've seen it go from pinkish-white and sandpaper rough back to shiny red).
Dash lights is probably corrosion on the dimmer wheel - left side thumb wheel under the pod. Sometimes a spin back and forth to each end of travel a few times will break through the corrosion enough to get *some* light.
Oh, and you forgot the important part of your first post.. pictures
Thanks for the tips.
Blower motor fixed
Dash lights better not perfect but better
Guards red well pink. I may do that till it body shop time.
Can I post pics? I have not really looked into it.
Is there a link some where on the Rus shifter install. Its a gt is it worth going all the way and install the
shifter while I have everything apart, or just go back stock with all new parts?
Owner said it had a new water pump and tb but never said when, and didn't provide the paperwork that he said he would.
Blower motor fixed
