Ground Radiator?
Ground Radiator?
I was searching around but didn't locate a thread about this. My radiator comes back from the local shop today. Was corroded pretty badly (all aluminum 928 int'l radiator). Said electrolysis ate it up pretty badly. I don't know how often Ron changed the coolant. Heads were pretty pitted as well when I did the head gaskets during last summer's rebuild.
Anyone ground their radiator to help alleviate the electrolysis issue? Where did you attach the ground wire on the frame?
I have my all-al grounded. It just developed a small leak this year after 11 yrs in service. I know that is not the norm however. I have it screwed to the side radiator mounting tab, but I'm sure a more formal location like the driver's side coil bracket would be better. I'm not convinced grounding has helped though and have read reasonable arguments against doing it. (not a 928 specific issue)
There was a good thread on this a few months ago though. Try searching on 'aluminum radiators'.
I haven't measured yet. Radiator shop said there was a lot of erosion inside and I should consider grounding the radiator. I am going to measure when I get the radiator back today. It is being epoxied.
$200 to epoxy it.
Another example. Get the stock stuff and you won't have an issue.
Had a Devek aluminum Rad on my car and it lasted all of 4 years. Buy a Behr, rebuild or otherwise and don't worry.
Ron. I did call 928 Int'l. He confirmed the age and you are right. But we are at about 4 years now. I bought the car from you in 2009 and you had it in about a year or so. Seems about par for these. When this one dies, I am buying a Behr from Roger now that they are available.
