928 Forum 1978-1995
Sponsored by: 928 Specialists
New super bulletproof transaxle
Old 06-13-2012, 04:05 PM
  #31
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,173 Likes on 1,229 Posts
Originally Posted by karl ruiter
Not only is this very very cool, but it might be salvation of 928 racing. I was starting to think that these cars would just be transmission limited and there would never be any possible solution.
We just need to keep bombarding Mike with demands to make more
It would be interesting to know if any other Jerico boxes would fit in the same location with these adaptor pieces for a more "road friendly" transmission.
Old 06-13-2012, 04:54 PM
  #32
Lizard928
Lizard928's Avatar
Yup, the only issue is that some classes require a stock case...
Either way, I want a price for one! And straight cut dog ring is good for me!
Old 06-13-2012, 04:55 PM
  #33
UncleMaz
UncleMaz's Avatar
This TA is perfect for my rear mounted twin turbo project.....
Then, my broke *** woke up.
This community never ceases to amaze. Bravo Mike!
Old 06-13-2012, 05:09 PM
  #34
Mike Simard
Mike Simard's Avatar
In NASA and SCCA the concern is a modified chassis and bodywork. The trans tunnel, wheelwells etc need to be untouched in order to be in the desirable classes such as ST.
I'm not aware of any requirement to use a stock trans case.
Old 06-13-2012, 05:17 PM
  #35
S4ordie
Not the sharpest tool in the shed
S4ordie's Avatar
Mike,
What an accomplishment! This is something really special. Looking forward to your track results.
Old 06-13-2012, 06:30 PM
  #36
dprantl
dprantl's Avatar
Amazing.
Dan
'91 928GT S/C 475hp/460lb.ft
Old 06-13-2012, 08:03 PM
  #37
Ducman82
Ducman82's Avatar
I'm on the road moving and just now check out the list..... Wow! Amazing work mike
Old 06-13-2012, 08:36 PM
  #38
Fastest928
Fastest928's Avatar
Sign me up for a kit... No longer need to minimize torque!!
Lots of old 4 spas around!!!
Well done!
Old 06-13-2012, 08:44 PM
  #39
blown 87
Rest in Peace
blown 87's Avatar
Neat stuff Mike.
Old 06-13-2012, 09:15 PM
  #40
Mike Simard
Just crawled out from under the car.
Here it is sitting on a jack. It looks like there's ample room!
I was also interested in the ground clearance.
The 928 pinion gear is unique in that it is on the axle CL. Everything else such as Vettes and my GM R&P sit below CL. You can see that offset in the first pics, the pinion is 1.5" below CL, a vette is a little more. That makes low hanging stuff a concern.
it looks like my Jerico will have the same ground clearance! It's amazing this is all actually working out. The idea of the pinion being that far off would usually rule something like this out right away. The GM ring gear is also larger and the pinion too.
Now I have to make the TT housing. Still lots to do!
Old 06-13-2012, 09:27 PM
  #41
BC
BC's Avatar
Well, now I know why I kept my 78 body after I tore all the PC stuff off of it. So I can put in ONE OF THESE!
Old 06-18-2012, 02:09 AM
  #42
justaguy
justaguy's Avatar
Mike
That is very cool. As a machinist and a 928 racer I have to say congratulations that is no small accomplishment.
Sean
Old 06-18-2012, 12:50 PM
  #43
OBehave
Former Vendor
OBehave's Avatar
Not to rush you or anything Mike but when do you think you will have this done tested and massed produce for sale? I just broke 4th gear in my track car yesterday at Watkins Glen and New Hampshire is 2 weeks away. any progress?
Old 06-18-2012, 01:08 PM
  #44
Mike Simard
I've broken 4th gear too, what a small world!
After breaking that trans I put in another and broke it right away, I don't even take the cover off to see why anymore.
I'm working on the TT now, that means designing one from scratch but it's going well. I would guess 4 weeks total.
Old 06-18-2012, 01:17 PM
  #45
BC
BC's Avatar
Which direction are you going with the TT? Aluminum tube and stronger center shaft?
Quick Reply: New super bulletproof transaxle
