928 Forum 1978-1995
Sponsored by: 928 Specialists
central locking button
Old Jun 5, 2012 | 07:41 PM
borland's Avatar
borland
Sorry. Fuse 17 provides constant +12V direct from the battery.
Switched power (15-bus) is provided to the central locking relay through Plug O, pin 13 (BK/GN wire).
Try measuring +12V from Plug O with ignition switched on and then off.
Old Jun 5, 2012 | 08:17 PM
westija's Avatar
westija
Not trying to kidnap the thread, Borland, which is the central locking relay?
Old Jun 5, 2012 | 09:18 PM
Kevin R.'s Avatar
Kevin R.
Plug O, pin 13 has two BK wires.
Plug Q, pin 13 has the (BK/GN) wire. It has THREE in that pin.
With the voltmeter, it powers on with ignition switched on and powers off with ignition switched off.
What's next?
Old Jun 5, 2012 | 09:42 PM
borland's Avatar
borland
Looks like the central locks control unit might need replacement.
But first... Have you said that the locks work with the key in either of the side doors, such that both doors unlock and lock together?
Old Jun 5, 2012 | 09:59 PM
Kevin R.'s Avatar
Kevin R.
Yes, that is correct...
The locks work with the key in either side door, locking and unlocking together. Even the rear hatch will lock the side doors when the key is turned to the left.
All that works perfectly.
Old Jun 5, 2012 | 10:40 PM
borland's Avatar
borland
Then it must be the control unit (p/n: 928.641.602.05) is defective. It's located just inboard of the center console side carpet piece, just below the stereo head unit. That part is used on 88-95 cars, so you might find one used on eBay.
Old Jun 5, 2012 | 11:27 PM
Kevin R.'s Avatar
Kevin R.
What else does this control unit do?
How sure are you on a scale of 1-100% it is defective? Do you know of these units failing, as in a common problem?
Old Jun 6, 2012 | 12:30 PM
borland's Avatar
borland
Lock functions, like you'd expect.
Sure? That's a bit hard for me to access on my end with such limited information. You be the judge.
Old Jun 6, 2012 | 02:04 PM
Kevin R.'s Avatar
Kevin R.
Okay....
What about the central lock button panel? Is there a way to test this? How common do these fail?
Old Jun 6, 2012 | 02:25 PM
Avar928's Avatar
Avar928
I'm watching this thread for clues to fix mine. Mine doesn't illuminate/work at all but the doors lock/unlock fine. AC button works though.
Old Jun 6, 2012 | 03:42 PM
Alan's Avatar
Alan
Electron Wrangler
The lock panel is a switch and light - if they work its not that.
The lock controllers are different by year <'89 is one type (based on the lock type). '89-'90 are different (with new locks) and 91+ are different again (integrated into the alarm/lock/interior light module).
Alan
Old Jul 10, 2012 | 08:30 PM
nexty226's Avatar
nexty226
Im searching, but in all the post made here ,you guys don't have a non functional looking button. My 86 does not lit the button light. Also the door locks do not work either with the key. Yesterday I did a wire check and had volts on the wires that goes through the doors. I din't found anything. My central warning unit was badly fired, I intalled one new on sunday, now I have all my lights working on the cluster. Need some help to see if I have to replace the central locking unit. Does anybody had a absolutely NOT working locks I mean anything that could give some clue??? Thanks..!!!
Old Oct 28, 2012 | 09:35 PM
Kevin R.'s Avatar
Kevin R.
Okay, it has been a few months since this post was used. Time to revisit to see if there are any new insights for this repair. Had the car away for four months so have to get back at fixing this "interior only" central locking issue.
Anyone had the identical problem they resolved on a MY 1990? Thx.
Old Nov 8, 2012 | 10:01 PM
Kevin R.'s Avatar
Kevin R.
Default Light Switch powers up lock panel button
Okay, here is the BIGGEST challenge yet to this problem.
With the car OFF, the light switch is turned to power on the parking lights. When this happens, the lock panel button is also powered on and works. There is no key in the ignition and no engine running. What kind of an electrical gremlin is this?
Of course the central lock button only works in the "open" position, as indicated earlier in this thread. Nevertheless, I thought this new problem might be related in some way.
Tell me I am not the only one this has ever happened to...
Old Nov 8, 2012 | 11:44 PM
jeff spahn's Avatar
jeff spahn
My lock button doesn't light in my 90S4 but functions correctly otherwise.
