Did Meteor Metallic paint use clear coat?
I am looking at a 928 painted Meteor Metallic and the owner says the car needs a re-paint due to oxidation. Having owned a car painted Meteor Metallic I don't recall there being a clear coat. Am I wrong?
I am pretty sure all metallics are clear coated from the factory...but I am standing by to be proven wrong. If clear coated the underlying paint should be fine, just need the clear coat polished.
Cheers!
Carl
90GT Project
Cheers!
Carl
90GT Project
Craic Head
Mine is Meteor Grey Metallic ('85). It's got a clear coat that's starting to show signs of wear here and there.
My car was resprayed at some point though, so it's not original. I imagine the clear coat was to emulate the original paint/clear coat combo.
It depends on the year. By 1987, most OEMs were spraying clear on all colors (even non-metallics). It is a safe assumption that high end cars were clear coated prior to that. Today, there isn't an OEM ouside of India that doesn't apply clear to all top coats. The primary reason for this is UV inhibition.
Ok, I was wrong. If the clearcoat is oxidizing can a competent body shop restore it without a full respray or should I suck it up and get the job done right?
Administrator - "Tyson"
Cheers!
Carl
Under the Lift
BTW, isn't that the best color?!
As did my 85 before it was re painted.
According to the Porsche "Two coat Metallic Paint Repair Procedure" manual, the metallic paints ARE base/clear, in other words, a base color coat with the metal flakes, covered by a clear coat. I know that many solid colors (i.e. Guards Red etc) were single stage (i.e. no clear coat)
Cheers!
Carl
90GT Project
Cheers!
Carl
90GT Project
Nearly all metallic paints from at least the early '80's forward (and for all I know maybe EVERY metallic and pearl from the beginning of time) were clear coated...
Craic Head
