timing belt warning
Just a little aside if you are going to check the tension yourself as a first timer. You will have to have the car securely raised. 6 ton floor stands x 4. Good low sitting jack. I recommend Porken liftbars for future work (http://liftbars.com/).
Once raised drain coolant from radiator. When replacing drain plug minimal torque (this Tech site has torques you should have https://docs.google.com/file/d/0BzC7...jI3/edit?pli=1), I believe 1.5Nm. You will need at 27mm 1/4 in. driver to rotate the crankshaft CLOCKWISE to TDC 0 deg. You WILL rotate crank two times past 0 deg. to TDC. You will measure tension at TDC.
Have fun.
http://members.rennlist.com/v1uhoh/checking.htm
For changing the belt/ water pump etc:
http://dwaynesgarage.norcal928.org/1987 Timing Bel
Have fun.
Since I am waiting for the t-belt tension tool to come. I am playing with my car by fixing up some other things in the interior and eletrically.
Also, I had checked the t-belt warning wire coming out from the cam cover when the engine is not running. it seems to have a good earth.
Cheers.
http://www.2010.cannell.co.uk/manual...s_porsche.html
And also the "Timing Belt" section of this page:
http://members.rennlist.com/pirtle/svc.html
As John SPeake notes above - there's a 3-minute delay before the warning system will report low belt tension, unless the warning system itself has failed.
The usual culprit is the either a break in the wire from the nose of the tensioner to the little brass angle piece, or the connector from the timing belt cover coming off the little brass angle seen at the top of the green loop in my picture.
As Bill notes above - the wire is sometimes a flat copper bridge which is prone to breaking - although my hazy memory says that was only used until 87 or 88, and that 89 onwards has the wire.
Thks.
-adjusted the T-belt tension
-added oil in the tensioner
-ordered the carpet set from Garage 9 and had changed the whole car carpet
-fixed the leaking front automatic fluild hose
-fixed the leaking power steering hose
-fixed the headlight fine adjustment motor.
-changed all speakers and installed amp and subwoofer
-fixed a vaccum leak in the AC control panel
-connected the discounted wire of the idle stabling valve
-coolant and automatic fluid changed
-installed a keyless entry system and rear parking cam
-etc.
Upcoming
-install a rear spacer
-change the rear axle oil
-spark plugs change
Thanks for everyone and the forum to provide me advices and endless information. Without it, I will not be able to know my car this well. Now the car starts, idles and runs great. Gald to see that my car is getting better everyday. Working on the 928 is tough but very rewardable and fun. Hope I can up keep this youngtimer for a long time to come. Cheers.
