timing belt warning
When I asked what part of the world you're in, I was considering New England vs. the Southwest etc...
Join Rennlist so you can post pics that may help us help you. I don't know if you are considering working on the car yourself, but even if you're not this is the place to get the best guidance when confronting the dealership.
Best Wishes to you and yours.
Craig
Shameful Thread Killer
The valve timing system on the 928 has: 1 toothed belt, three toothed sprockets(gears, wheels), an idler, an oil pulley toothed gear, a water pump pulley, a hyd tensioner, four cams, two chains, and two hydraulic chain tensioners.
The parts replaced are all associated with the belt, and belt drive system on the timing. Its my guess that the timing 'chains' and sprockets under the cam cover have not been worked on. The are not a high failure item.
Order the PorKentioner from 928sRus, he ships internationally all the time. Remove the right side dist cap, and belt cover and test your timing belt tension. While the cover is off, visually inspect the teeth of the belt under a high intensity light. look carefully for cracks at the edge of the teeth. Look on the under side of the timing gears on each bank of the cams for wear. The shop has said they replaced them, it's best to check this carefully, they should show very little wear. Inspect the tensioner system for leaks, and repair/replace as necessary.
Put the cover and dist back on and start the car. Wait 5 minutes and see if there is another tension alarm. If not, go drive for a while, but plan a timing belt replacement soon. If there are more alarms, investigate the wiring at the CE panel which supports the alarm circuit. We will help you with the location of the wiring.
Use this link to help you identify things. Also has The PN's (Part Numbers)
http://www.porsche.com/all/media/pdf...91_KATALOG.pdf
The fill is on the left. The bleed is on the right. What are you considering to use ?
Add: View this - will be helpful.
http://members.rennlist.com/pirtle/tbelt.html
Kevin,
For great pictures, go to www.dwaynesgarage.norcal928.org
Look for the write-up, near the bottom of his list of tutorials, for 87 timing belt and water pump.
Study this writeup and you will be fully conversant.
Chances are you will need belt retensioning, which you can do yourself with some gymnastics. But its best if possible to have a known-expert disassemble and review everything.
928 is a car that most dealers in the US won't touch because they are no longer trained / knowledgeable. Too risky and costly for them and you. Maybe its different in HK.
Thanks for everyone inputs, great info. Really help me figure it out and understand my situation much better.
"Remove the right side dist cap, and belt cover and test your timing belt tension. While the cover is off, visually inspect the teeth of the belt under a high intensity light. look carefully for cracks at the edge of the teeth. Look on the under side of the timing gears on each bank of the cams for wear." >>>Yes, I think I will do that at least to have a further investigation.
In order to do so, do I need to remove the coolant hoses and drain the coolant first?
I've used the Kempf tool for years to measure tension on my belts. Go to 928Int'l or 928Rus .com to get yourself one. It's inexpensive.
