Parting a '91 GT
#46
So, I pulled the top cover and differential end cover from the transmission tonight. The internals appear to be in very good shape. The drive shaft turns easily, so I was able to inspect all the gears visible from the top, and I saw no signs of wear. The gears look brand new. Same with the view from the end into the differential.
If anyone is interested in buying the complete transmission, I will sell the complete transmission for $2600 or without the PSD for $2200 (plus shipping). The transmission will be sold as is, so the buyer probably shouldn't expect to just fill it with fluid and go. Personally, I would want someone knowledgeable to go through it if I was going to install it in my car. I am happy to take any pictures requested and to disassemble the transmission as far is necessary to get reasonable information requested. However, I am not a transmission builder (and don't play one on TV), so I will not be reassembling the transmission. Anything I disassemble stays that way for the next owner.
If there is no interest in the complete transmission, I will list prices for the individual components once I begin to disassemble it.
#48
Brad,
Here are two pictures of the cluster (I took them last night without cleaning the cluster up first). It looks to be in reasonable shape except for a spot under the battery gauge where it looks like a small spot has peeled (and the gas gauge needle is off). The connectors and the cluster are yours if you want them.
![](http://i258.photobucket.com/albums/hh265/gwgjr33/928%20heads/cluster2.jpg)
![](http://i258.photobucket.com/albums/hh265/gwgjr33/928%20heads/cluster.jpg)
#59
Hey Gary, I know this is a pretty small item ... the cover is missing off my power seat relay (looks like this photo). This thing mounts on a bracket just atop the ABS controller in driver's footwell. Can I have your bad one for the cover?
#60
Gary,
I know you are not selling any electronic parts. I have a 91 GTalso and the seat connector is broken. It iis the plastic piece that holds the pins together on the seat side. Can I have that x 2.
