928 Forum 1978-1995
Sponsored by: 928 Specialists
Coolant level sender o-ring
Old May 10, 2012 | 02:15 PM
Randy V's Avatar
Randy V
25 Year Member
Just an FYI -
I bought a 397 piece nitrile (oil and coolant resistant) o-ring kit at Harbor Freight for a mere $6.00. It has several each of many different sizes.
I originally bought it to replace the o-rings on the hose fittings when I replaced the radiator side tank.
This is the metric size kit - they also have a standard size kit:
http://www.harborfreight.com/397-pie...ent-67580.html
Old May 10, 2012 | 04:45 PM
Leon Speed's Avatar
Leon Speed
Originally Posted by kelanel
Thank you!! noticed mine has been leaking with the new resevoir (changed before i got it), pretty sure the o-ring is crumpled, good to have one on hand when i finally pull it.
Sorry, I made a mistake, it is ID 25, OD 32 mm (3,5 mm thick).
Randy, I have a similar blue box!
Old May 11, 2012 | 01:31 AM
kevinlieb's Avatar
kevinlieb
Sort of a bit off-topic: do you need to take the reservoir out to get the sender in?
Old May 11, 2012 | 01:34 PM
Randy V's Avatar
Randy V
25 Year Member
No, but it takes a bit of finagling. It helps to loosen the reservoir mounting points.
Old Nov 8, 2012 | 10:34 PM
westija's Avatar
westija
When inspecting my 89 S4 Expansion Tank, here is what I found. The Level Sensor floating part disintegrated inside the Tank. I found many of its pieces, (sorry for the blurry picture) but now it is anyone's guess if they are somewhere around the system.
Interestingly that when I did the PPI, there was coolant level warning message, when I met the PO again the next day, he told me he fixed it and the message was gone. Well, the wire was disconnected from the sensor.
File Type: jpg
File Type: jpg
Old Nov 8, 2012 | 11:14 PM
Bjbpe's Avatar
Bjbpe
How do you get the tank out to where you can remove the sending unit. Pretty tight quarters.
Also, for Randy. I thought you were from the Soo. Why would you want to live near palm trees?
Barney from the Keweenaw. If you don't know where that is, I suggest you can no longer claim to be a Canuck and California just does not cut it. A man without a country (home)!
Old Nov 8, 2012 | 11:46 PM
westija's Avatar
westija
To remove it, you have to remove two 10 mm screws that hold the tank to the car, unplug the connector from the sensor (mine was already unpluged thanks to the PO), unscrew and remove two small hoses that connect to the top of the tank and unscrew and remove the hose from the bottom. All in all fairly quick, but yes a bit tight. You may want to drain the coolant or suck it with a manual pump or something. Mine was pretty low because I just finished the Intake and so did not have to worry about that.
Old Nov 9, 2012 | 01:36 AM
NoVector's Avatar
NoVector
Thanks for reviving this thread. I just bought a new tank and was looking at the sensor wondering what size o-ring it took. Nothing in the PET...
