928 Forum 1978-1995
Sponsored by: 928 Specialists
Where does this hose go???
Old 04-18-2012, 05:38 PM
antlee928
antlee928's Avatar
Default Where does this hose go???
Hi, pulled the RF wheel liner yesterday to check the infamous Y-connectors and
sure enough it was broke - one piece now equals 4 pieces. This explains the fuel
smell from the front and particularly in the cabin when I have completely filled
the tank!
Anyway, I was poking around in there and noticed a loose hose coming off the top
section of the washer bottle. Not immediately apparent where it should be
connected. I have seen a pic showing it looping back and going somewhere in
behind the carbon canister but again not clear as to where it should be
connecting???
Any assist will be greatly appreciated before I fix/replace the Y-piece and
reinstall the liner.
Cheers
Old 04-18-2012, 05:44 PM
993turbo
993turbo's Avatar
Overflow drain / air vent. Does not go anywhere.
Ohhh, it looks sparkling clean there, well done!!!! :-)
Old 04-18-2012, 05:57 PM
laufenOutLoud
laufenOutLoud's Avatar
Wait a minute... I take back my comment. I was not aware the washer bottle had an overflow. Also, the overflows I've seen are rubber, and don't have the material jacket.
I change my comment to: I'm not sure! No help...
Old 04-18-2012, 06:05 PM
993turbo
993turbo's Avatar
Simple; If you overfill the washertank, the liquid will come out this hose. (Overflow drain) But before this happens air will come out of the same hose as the air in the tank is replaced by the liquid during filling.
When you use the windshield washers, or the headlamp washers the pumps pump liquid out of the tank. This space need to be replaced by air, if not the tank would be sucked flat. So Air will be drawn into the tank through this hose. (Air vent)
Old 04-18-2012, 06:17 PM
antlee928
antlee928's Avatar
Hey thanks team for the fast response. That was my only thought was some sort of overflow since it comes off the bottle near the neck. So I will just tie wrap it down so it doesn't flap about.
Yep, I like to keep her pretty clean. The car is in very good condition for an 89'er.
Oh, and here is my old Y-connector. All three connectors broken and thus explains the very strong fuel smell especially when I fill the tank to full!
Cheers
Old 04-18-2012, 08:25 PM
brutus
brutus's Avatar
Yes the fuel vapors get trapped under the fender get sucked up by the heater blower motor and pushed into the cabin.
Old 04-19-2012, 04:53 AM
antlee928
antlee928's Avatar
Nothin' like the smell of hi octane in the mornin'....... ;-)
Quick Reply: Where does this hose go???
