New Stroker Crank Available for Sale
Rob just post the pictures of 100 MM S-4 pistons and the much shorter GTS vs the very short with raised wrist pin 104 mm 944 pistons which was needed to pack that much stroke into the same deck height block. And yes having skirts hit the crank counter weights was a big issue, Devek was known for using a grinder to clearance the skirts on some of their builds.
This is Moldex crank and 968 pistons in S3 block. I'm not sure if one Carl is selling has equally larger counterweights or not. My crank has 8 weights so its not exact same anyway. I had to machine some material away from weights to clear piston bottoms. All shiny areas on weights have been done to give 2-3mm clearance at BDC. There were no hope in rotating crank full 360 degrees before it was done.
Archive Gatekeeper
I don't have a comparo pic of an S4 vs GTS vs. 968 piston vs. a JE stroker piston, but I will try to get one tomorrow. In the mean time, here's the diff between the S4 and a 104 mm JE piston.
Carl, my apologies for fueling the semi-off topic-ness here, but hopefully it will help illustrate what your crank buyer will also need to source. $2400 for a Moldex crank, in stock, is a steal!
This photo also answers the thread about oil drain holes in the S-4 piston. Note the two holes drilled to relieve oil trapped in the pocket around the wrist pin on the S-4 piston. Also shows the raised wrist pin and how the rings MUST be moved closer together just to get things to fit.
In case someone wonders what crank balancing means this video shows whole process starting from measuring rotating assembly weight. Only difference to 928 crank is that damper and flywheel is not mounted in 928 setup as our cranks are usually internally balanced.
Basic Site Sponsor
Basic Site Sponsor
Greg;
Thank you for the feedback on our engine wiring harness. Glad you liked it.
I do not encourage anyone to use the wrong rods or rods with the wrong offset. Of course not.
And I do not see anywhere in my post where I encouraged people to use the wrong rods.
I mentioned the SBC bottom end specificaly because I do not want someone to think they can just drop this in their 928 with the stock rods.
As it says on our webpage for this item: "NOTE: Stroker crankshafts require careful measurement by an engine assembly professional to select rod length and piston crown height to use with the crankshaft."
I'm glad you use the Carrillo rods. No question about their quality, but a little pricey I think. I have Oliver rods of the correct 928 offset for the Chevy rod journal and both the metric and "Chevy" wrist pin size. The Oliver rods have done very well for us.
So there you go, Mr. Rennlister: if you want this crank, both Greg and I have rods in stock for it.
I recently took apart one of Mark Thomas's "stroker" engines that had less than 5,000 miles on it. It also had a set of Oliver rods...which manifest the exact same problem! None of them are quite to the .003" "out of round" stage, but there are a couple that are close to .002" out of round. I can't deal with that...it's hard enough to build these engines without unknown quality parts.
My first experience cured me. The second experience confirmed my thoughts. After all, most all of the "other" rod manufacturers "hang their hat" on making "cheaper" rods than Carrillo, but they never seem to claim that they are "better" than a Carrrillo. Since I'm into "uber" quality pieces and results, Carrillo is the only way I "go", these days. A couple of dollars saved on the price of a rod just doesn't seem like the place to save money, to me.
Of course, I also realize that other people will have different experiences/expectations. That's what "choice" is all about.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Developer
I havent had a set of Oliver rods fail yet, even at 900 HP. Of course, no rod will last long if abused or installed wrong. Always easy to blame the rod, but never overlook 1) the application, or 2) the engine assembler, or 3) the engine machinist.
But, you know this.
But, you know this.
Developer
Guys - not a problem with the thread going in direction of what else you need to make a stroker.
In broad brush strokes, here is my quick-list:
Custom pistons - either with short piston skirts or high wrist pin placement (partially into the 3rd ring groove) or both.
Rods to connect those pistons to this crank that are the right length that, with piston, arrive at the compression ratio you desire.
Clearancing inside the block for the throws.
A 928 oil pan spacer, and lengthened pick-up tube.
...and you also get to select con rod fasteners, rod bearing coatings, wrist pin retainers, piston skirt coatings, piston crown coatings, and piston ring format while doing the stuff above.
This is not a complete all-inclusive list, but just wanted to round out the items you are looking for a bit.
Basic Site Sponsor
Basic Site Sponsor
But, you know this.
But, you know this.
And I'm having a tough time "dreaming up" a situation where an engine builder could make a rod "go out of round"....with no damage to the crank or the bearings...but that's just me!
I realize that this "high output" engine building experience is fairly "new" to you and you've got a "long way to go" and a lot of lessons to learn, before you perfect this art...that's also a given, in this discussion.
Unfortunately, if people ignore what others have found out...they have to "learn" as they go...and pay the "price" for these lessons.
Understand that I have nothing to gain in this discussion....it's just a discussion, for me. I'm just the small guy building engines...you are the giant marketer of all things 928.
I'm actually completely overjoyed that you want to use SBC offset Olliver rods in your engines....and completely encourage you to continue to do so!
I'm just hoping I can "help" the other people, with my knowledge/experience.
Again, nice wiring loom! Great product!
Developer
I'm not going to argue one rod manufacturer against another. I did point out that although all rod failures are blamed on the rods, there are other factors.
Carrillo makes and excellent rod. But a Google search for "Carillo Rod Failure" or "Carillo Rod Problem" will show that no matter who you are, there can be issues.
Now - can we talk about the crank?
Developer
I haven't had a rod failure in one of the engines yet, although at these performance levels, I certainly might. Let me just say, we are waiting to see what the next failure mode will be at this level.
Under the Lift
Carl said:
"I have Oliver rods of the correct 928 offset..."
Greg then said:
"I'm actually completely overjoyed that you want to use SBC offset Olliver rods in your engines..."
