Center Console Lighting Problem: Blowing Fuse
I recently had oodles of work done on the car, so the problem could be almost anywhere but I suspect it might be related to work done on the pod. The pod height adjustment locking lever was broken and was replaced. It seems to me somewhere back in my memory that the lighting for the center console gets it's juice passed on from the pod and potentially the rheostat. Anyone remember if that's the case? Should I be looking elsewhere for a reason the #9 fuse keeps blowing?
The other items done on the car: complete intake refresh, sharktuning, new bellhousing with all new parts other than flywheel, new shocks, AC refurb (front and rear), PSD pump replaced, all new vacuum lines, all new fluid lines (brake, fuel, power steering), new brake master cylinder.
Also, I think maybe the speaker wiring was redone but the other stereo wiring (power, grounding, etc) was not touched.
Any suggestions on where to start looking for the short?
Thanks,
Dan
Last edited by Manfred; Apr 15, 2012 at 06:11 PM. Reason: incorrect information given initially
Check what the potentiometer is connected to - may be incorrect...
Alan
The fuse does not blow until I turn on the headlights.
Potentiometer appears to be connected correctly--there is a two prong keyed connector (only allows it to be connected one way). IIRC--there is some other two prong connector back there that is not used in US models (frequent question when people are poking around back there and find a connector not connected to anything). Maybe in the pod work the wrong connector got hooked up...
The wires going into the potentiometer are yellow and yellow with red stripe.
Anyone have any other ideas on where to look?
Dan
Seemed you said it blew the fuse even without this in circuit though?
What else has been changed in the console/pod?
Do all the other pod functions work normally? is the bulb check working correctly - all illuminate?
Alan
Yeah, the pod instrumentation lights up as expected and the bulb check function is working fine as well. And as you said, even if the connector was the wrong one, it should not blow the fuse with it disconnected...
Nothing else was done in the pod other than fixing the height adjustment lever but I'm not sure how much of the pod was disassembled to accomplish that.
Anyone know the routing for the center console lighting? The wire is shorting out somewhere between fuse #9 and the center console. If it goes through the pod first, then the short must be between fuse #9 and the pod as it shorts even if it is not passed on through the potentiometer.
Dan
If you disconnect the dimmer rheostat (to be clear: the one on the left side of the steering column, with BK and BK/BL wires on the connector), it doesn't leave much connected to the output of fuse #9. It's likely you've got a pinched black wire somewhere. I'll take a look at the routing of it on my car as best I can and get back to you. It does pass through connector T5, which, IIRC, is behind or somewhere near the pod.
Thanks Ed. I'll report back...
Dan
What's the saying, "Garbage in, garbage out"?
Well, turns out what I was calling the pod rheostat was actually the wiper delay. Stupid thing is hidden behind the wiper stick so I can't see the labels from the drivers seat. I was without the car for about a year so I forgot that the pod illumination dimmer is on the left hand side.
So, anyway, unplugging the wiper delay swich (and in fact really cleaning out the wiper delay switch) has no effect on my problem--go figure!
I've changed the original post, deleting the part about the pod dimmer switch not working.
I guess I will inspect the dimmer switch as it still may play a role in passing juice on to the center console...
Dan
With the dimmer in the circuit, all the BK/BL wires are involved, which is all sorts of back-lit stuff (pod switches, various things in the center console, etc.)
Note that the dimmer itself cannot (in any way that I can see) be the cause of the failure you're describing. The dimmer rheostat ranges from approximately 0 Ω (i.e., direct short across the terminals) to about 6 Ω.
So, I took out the actual pod illumination potentiometer, and the fuse does not blow.
I guess that means either the potentiometer is the problem, or the problem is somewhere between the potentiometer and the center console.
Can I bypass the potentiometer by simply bridging the connector to see if the fuse blows? If it does not blow, that would implicate the potentiometer. If it does blow, that would mean the problems is further down the line.
Dan
With the pod illumination dimmer removed the #9 fuse does not blow and the ashtray light is coming on normally, but still no HVAC or clock light.
