Spark Plug Wire/Distributor Setup HELP!
This is for an '86 928S 32V Auto
Anyone have the set up for the spark plug connectors to distributor cap? I'm currently in the middle of changing it out, I had to take out more than I thought during dis-assembly and in my frustration because of seized bolts and the screws, I didn't label them =.= The wires were so dry and crumbly I had to wire cut some of them out because they were rock hard to bend.
Thanks pjg.
Ahhh, bad news. Found oil in the spark plug hole of cylinder 8. It soaked the ignition cap too. Crap
+ Add:
After reading up on some past rennlist threads, it looks like the valve cover has to be removed on the driver side and the spark plug seals replaced. The leak is only on 8 and a very very very slight start on 7. Going to be tough getting that cover out =.=
+ Add:
