Fuel injector replacement question
Since I bought my '81 NON euro 928 Ive read quite a bit and not been able to really figure out this thing about those who are using Ford injectors. Are they direct replacements or do I need to modify the fuel rails and or anything else? If they are a direct fit does anyone have the part # for them? Last but not least is there a big advantage other then replacing 31 year old injectors with fresh ones?
here you go.. "Improved Design: These 928 Motorsports LLC custom injectors will fit your existing intake manifold, and allow you to upgrade to the more common late-model 928 fuel rail or our 928 Motorsports aluminum fuel rails. Gone are the little 2-inch hoses to each injector and all those clamps! " You need to change fuel rails to the late style but still not sure about flow rates but seems Carl is selling the conversion and new injectors.
I think it's more than just physical fitment.
L-jet = Low impedance
LH = high impedance
Most late model injectors, including the 5.0's, are high impedance. Electronically, I don't think they are a drop in.
928MS and Roger both sell direct replacement low impedance injectors for the L-jet cars.
LH = high impedance
If you are interested in replacing your injectors, ducman82 was selling his 928ms ljet injector set along with his spider, and fuel rails for a pretty good deal with only a few miles on them. i was thinking of jumping on them but suspension is first on the list for me right now.
Link:
https://rennlist.com/forums/928-foru...spider-fs.html
Link:
