928 Forum 1978-1995
Sponsored by: 928 Specialists
Water pump guide pin missing - is it required ?
Old Mar 24, 2012 | 06:47 PM
pjg's Avatar
pjg
Default Water pump guide pin missing - is it required ?
Seem to have lost one of the guide pins while replacing the water pump, do I need this, will it leak without it ?
File Type: jpg
Old Mar 24, 2012 | 06:51 PM
Andre Hedrick's Avatar
Andre Hedrick
Rest in Peace
I had the same issue, used a wood dowel for alignment and to hold the gasket in place, and everything appears fine after 6 months. Others comment?
Old Mar 25, 2012 | 01:11 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
I would put one in,
a used shank of a drillbit can be used,
turn it down in the drill till it fits.
then cut it off with a dremel cutoff wheel.
the pins keep the pump from moving on its gasket,
it will move when the pump gets hot and the T belt is pulling it up,
thus loosening the belt, and possibly shearing the gasket
Old Mar 25, 2012 | 10:21 AM
pjg's Avatar
pjg
Originally Posted by Mrmerlin
I would put one in,
Thanks, I'll try the drill bit idea.
Old Mar 25, 2012 | 10:45 AM
GlenL's Avatar
GlenL
I suggest finding the size and ordering a box from McMaster-Carr. I did this for head guide pins. Surprisingly cheap and you'll have a lifetime supply.
