928 Forum 1978-1995
Sponsored by: 928 Specialists
Clutch Spring Washer Position.
Old 03-17-2012, 04:54 PM
Mako 928
Mako 928's Avatar
Default Clutch Spring Washer Position.
O.K. maybe I am over thinking this but, What is the correct position on the Spring Washer?
Is the convex or concaved side supposed to be facing the throwout bearing?
The WSM only shows the diagram and it is hard to tell but also states to " position correctly" so I assume there is a reason for this.
There is more tension on the pressure plate fingers if the Spring washer is flipped from convex to concave so there should be a reason for this.
Old 03-17-2012, 05:33 PM
pjg
pjg's Avatar
Look here: http://www.lindseyracing.com/LR/Parts/TECHTO.html
or
http://members.rennlist.com/sharkski...R30-Clutch.htm
Old 03-17-2012, 06:12 PM
SeanR
SeanR's Avatar
You've got it right.
Old 03-17-2012, 06:40 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,612 Likes on 1,260 Posts
[piling on] Yep. [/piling on]
This is for the SD clutch, but it shows the 'concave up' position nicely:
Old 03-17-2012, 07:06 PM
Mako 928
Mako 928's Avatar
Thanks guys I have been stressing on this since yesterday and could not come up with the answer.
After completing the TT rebuild I started having shifting issues with the clutch and have not been able to drive it since then.
Back into the garage to finish this up once and for all.
Quick Reply: Clutch Spring Washer Position.
