Arrow on air filter
You should ignore the arrows, as there have been reports of air filter elements with arrows in the up direction and in the down direction. The air filter mounts with the convex side up. Note that if you have already installed the air filter upside down with any running time, you should leave it as is, rather than correcting the orientation and then sucking the trapped dirt into the engine.
Here is a picture that I saved from another RL post (apologies, I don't know who to credit here). The picture shows two air filter elements oriented the same way, one with the arrows up, one with arrows down. As I said, I recommend that you ignore the arrows.
Credit to Ed Scherer!
Ed, thank you for posting the picture with the arrows up and down. This is one of those memorable pictures that is truly worth a thousand words.
