Early x-member with late mounts
so all i have to do its drill the holes for the locating pins on the later mounts, so they sit nice on my early x-member right?
If you just drill the holes in the early crossmember and install the new style mounts, the oil pan cannot clear the mounting plates on the mounts. Distance between the mounts will be too narrow....I know, hard to believe.
Very subtle difference in shape of new style crossmember.
Rich
Rich
Easy enough to put in a later style crossmember.
Rich
Can I send it on Saturday?
got the late model cross member installed. took about 1.5 hours. whew.... did it without dropping the rack. so what hole does the stud for the motor mount go it? outside holes, or inside ones?
Ok so here is what i did
removed control arms bolts
removed A-arm supports (xmember to top control arm nut)
removed rack bolts and steering column coping (marking for position)
then removed last 17mm bolt on back top of xmemeber
when it was loose, i pushed rack down a bit, and then kicked out the pass side of the crossmember to the back of the car. then pulled the driver side of member to the front. popped right out for me. install was in reverse.
