knocking sound .....
Man of many SIGs
Cut open the oil filter. If it were a knock and sound that bad you should see some metal in the filter. It sounds like something is loose to me.
Under the Lift
OK, so I would describe that as a rattle, not a knock. It's a vibration, not a rhythmic knock that matches RPM, so, I don't think it's anything like a rod or other part of the rotating mass. It sounds like a loose bracket, say, for the air pump diverter valve, rattling against the block. It sounds like a broken cat coverter core rattling in the exhaust, although you have tracked it to the block rather than the exhaust. Perhaps it is the shield plate above the AC compressor - at least my 89 has one. Perhaps it is the heatshield near the motor mounts. Whatever it is, it doesn't sound internal or rod knock-like. I wouldn't be cutting any filters unless it's time for an oil change.
No ports or emission stuff on the car anymore. Getting it up in the air (rack) and delv a little further today. It's more constant now, compared to that video.
sound is mostly coming from driver side exhaust...... but not really the block. we think its a broken valve spring. so this week/weekend I'm going to take the drivers cam box off and take a look.
all tools are accounted for. with scope you can Really hear it on numbers 5-6. at speed it barley makes any noise, so the valve likes to float... going to take a plug out when she is cold and take a look......
last night i took the driver side cam gear cover off, moved the belt a little and saw this....... wow its worn... some oil seeps and everything under that cover.. ugh. now my debate is this,
take apart and fix the springs (if that is indeed the case)
or remove the old girl, and clean up the engine bay while building up the hybrid..
