928 Forum 1978-1995
Sponsored by: 928 Specialists
knocking sound .....
Old 03-05-2012, 08:16 PM
Ducman82
Ducman82's Avatar
Default knocking sound .....
Driving this evening I noticed a knocking sound when parked in nutral but only when i rev the engine then take my foot off the gas...... Sounds like it from the clutch area, but I've never had a clutch issue, shifts fine.... Hummmm
Old 03-05-2012, 08:20 PM
Ducman82
Ducman82's Avatar
http://i575.photobucket.com/albums/ss197/Ducman82/78b836fe.mp4
Here is a link To a video I took. Oil pressure is great.
Old 03-05-2012, 08:40 PM
NC928S4
NC928S4's Avatar
Could it be something vibrating/ rubbing on the forward heat shield? Or possibly a loose bolt-washer vibrating. Lastly and unfortunately, it sounds more like a noisy bearing.
Old 03-05-2012, 08:48 PM
Ducman82
Ducman82's Avatar
When I get home im going to get this puppy in the air. Maybe some kind of exhaust bracket/ heat shield rattle.... But would a rod make that noise on decel only? I'd figure a rod would do it all the time, even idle....
Old 03-05-2012, 09:30 PM
Fabio421
Man of many SIGs
Fabio421's Avatar
That sounds like somethings loose under there. It doesn't sound like a knock to me. Crawl under there and find it so you can set your mind at ease.
Old 03-05-2012, 09:42 PM
cpayne
cpayne's Avatar
maybe a loose hanger
Old 03-05-2012, 09:46 PM
Ducman82
Ducman82's Avatar
I'm sitting in my math class going crazy with horror possibilities going around in my head . Almost out of class then, ten. 5 mile drive home. The. Up in the air it goes
Old 03-05-2012, 09:56 PM
namasgt
namasgt's Avatar
Did you change the bushing under the air box for the clutch arm?
Old 03-05-2012, 11:12 PM
Ducman82
Ducman82's Avatar
Well.......... got her up in the air on lift bars and had the wife start it and give her a little gas.... sound is definitely from the engine. i used my stethoscope and and touched it to the clutch bottom cover got no noise, but i DID get the noise from the headers... more so from the driver side rear. could a pilot bearing do that? I'm thinking a Rod (worst case) but oil pressure seems good.
i think the 4.5 knows I'm building another motor....... so its mad...
Old 03-05-2012, 11:21 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,507 Likes on 1,412 Posts
pull the dipstick and drip the oil onto black cardboard look at the oil in the sun with a magnifying glass if you see metallic s then your gonna have to go deeper
Old 03-05-2012, 11:41 PM
Ducman82
Ducman82's Avatar
i checked the oil and it looked ok. but ill do the sun trick tomorrow.
Old 03-05-2012, 11:58 PM
snoz
Addict extrordinare
snoz's Avatar
I'm not familiar with a 928 rod knock noise, but this doesn't sound like any rod or main knock I've ever heard on other motors.
Old 03-06-2012, 12:00 AM
Ducman82
Ducman82's Avatar
that what i thought too. its not 100% constant. but varies in pitch with the throttle/RPM's.
im swinging it by the 928 shop here in town and my buds going to check it out and verify. i hope its stupid simple, but from what i could/couldnot find under the car....... ill plan for the worst.
Old 03-06-2012, 12:05 AM
namasgt
namasgt's Avatar
If that sound was from the engine internal, it would have blown up by now. That doesn't sound like a rod knock. Go back under the car and take the rubber plug off of the bottom of the bell housing, where you can see the slave cylinders rod. have someone rev the engine while you're looking and see if the rod moves side to side.
You are saying no sound from the bell housing but its hard to tell with everything bolted up together. I had someone complain about their 84 5 speed making the exact same rattling sound every time the engine was revved. The Release lever had come loose banging against the bell housing. It could be something else, like a loose exhaust bolt. But I would check the release arm first. Did you change the bushing for the release arm?
Old 03-06-2012, 12:43 AM
Ducman82
Ducman82's Avatar
i have yet to replace that bushing, but i did not se any side to side movement from the slave when i was down there. looked up with a light too... but being that everything is spinning quite fast, did not see much. could a throwout do it?
Quick Reply: knocking sound .....
