cold air intake?
Hey everyone I want to get a cold air intake or a new air box to enhance my cars preformance, what's the best thing to have? And we're do I get it
I have 87 s4
I have 87 s4
stock is best . pretty proven. just get that thing together and start driving it!!
lets get that fender flared like i did for the 6 liter and get those wheels and tires on.
check it out 1.5" of added space vs stock!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
these are 275s on the rear here!
You did that?!?!? YOUR HIRED! Lol yea idk what ct says but I have everythig ready to go just waiting for them, me and my dads plan is to have 300 rwp and the bypass isn't going to be enough
Ah don't..
Clearly the tinker bug is biting hard...so for the intake- the car, when all the components are in place and functioning, is set up to take (relatively) cold air from in front of the radiator. Factory CAI, of sorts.
If you want bragging rights or just to do something to it, you can look into the intake plenum expanders...that should be fairly benign. Unlikely to mess anything up/add stress, but you won't likely see much gain either.
Your low hanging fruit for performance is going to be exhaust as discussed in prior thread- properly designed x pipe and reduced weight if other components are replaced. Thereafter, you can look into getting it better tuned via a shark tuner.
If determined to roll the dice in a fit of youthful vigor- get nitrous or start saving the cash for a forced induction install .....but you probably have a ways to go to be sure the basics are sound enough to support any such thing.
I like that intake mod ! cardboard has low heat transfer, the aluminum foil lining is low resistance , red graphics for bling. And the exhaust smells like potatoe chips. Simple, easy, cost effective what more could you ask for ? 928s car utilize two or more for twice the power increase.
you dont need any mods to the engine. almost impossible to improve on what porsche did without making the car louder or costing a bunch of money. if you want power, you need the GT cams (which are kind of rare) or modified 85 cams to fit. (also time and money). the way you have it , it will be plenty fast.
just enjoy it. put on the exhauast mods, cat back and you are set.
Decide how much you want to swap out every two years to pass the smog inspection, they have gotten picky about so called cold air systems.
I've got two plans;
A) Copy what Porken did shrouding the AC and radiator so the front nozzles don't get hot air off of them.
B) Eventually cut some metal around the cowl to get cold air from the pressure zone in front of the windshield into the filter. This option can be kind of complicated, or sloppy, and I don't like sloppy much.
I've got two plans;
I've got two plans;
I've got two plans;
The EIS does smooth out the flow of air, which is why you get an increase of HP/TQ.
