928 Engine Porn... More pics added today
#46
Are you running a GTS crank? What rod bearings do you use, the stock/Glyco white bimetal bearings or an upgrade like the Clevite H-series or the ACL race series trimetal bearings?
http://www.aclperformance.com.au/Toy...TEBearings.htm
http://www.aclperformance.com.au/For...thBearings.htm
The only piston coating which seem to work 100% good in an Alusil bore is the Mahle Ferrocoating as used on the stock pistons. The optimum is to have the cylinders Nikasil coated or sleeved which make it possible to run any custom made uncoated pistons.
Ake
Ake
No one would Nikasil the bores in the UK. It was not possible to sleeve the cylinders as they are already sleeved by Porsche
Now, what do you think about this...
This is the Kolbenschmidt piston which came out of my GTS factory-sleeved motor. Ignore the damage to the skirt caused by lack of oil...
It does not look coated, does it?
And here is a picture of the liners. They are alusil as they are easily scratched with a screwdriver as per the Kolbenschmidt instructions. Yet, the pistons run without issues for 20k miles...
#48
Alex, Post 21 - square clips properly attached to top of fuel injector nozzles??? Looks like there is a groove near the top of the injector that the clip is meant to engage??
#50
Yeah, she idles like a ***** cat - nice and stable. Throttle response is out of this world - it just picks up like a F1 car. Next we are going on a dyno, experimenting with different horn lengths. It would be interesting to see what she makes with the original M5 long horns vs. the custom shorter ones I got made a while ago. It was nice to see her start on the button after 2 years of hibernation and settle down into a super smooth idle at around 900rpm. Good work on the cams, Colin!
#57
hes took the pics off so the other uk racers dont see the secret ingredients!
looking good alex, about time you got back out, im on my on out here takin these guys on lol!
regards mark
regards mark
#58
As to you taking the rest of the field on in the UK on your own - Mark, you are doing a mighty fine job! And you have been quiet about it! Congrats on winning the Deutsche Marque and coming 2nd at Combe in the Future Classics!!! See, you don't need me at all...
In reality, I want to drive the frikking thing so bad, that I may end up buying another GTS 5spd, just to be in a 928 again...
Btw, do you know where I can find a pair of brake ducts like the ones fitted to 964RSs and 993RS?
Alex
#59
sorry alex only just saw this. thanks the old 928 is going well, i think if id have put new tyres on instead of bein a cheapskate and using the same set all year i could of gave nic a better race in the future classics race. got a nice pic in autosport though. how far off are you from completing the racer?
we sell the brake ducts for 993 and 964, i think they are 75 pounds a pair, ill ask my dad monday if you still need them
thanks again mark
thanks again mark
