Re assembling rear suspension question
should i wait to torque the upper and lower arm bolts/nuts till the car is on the ground and "settled"?
and should i lube the hub pin? i had some normal silver anti seize on them when i removed them and it felt, kinda... puddy like. thoughts?
Any antiseize should work fine. Here in CA, I haven't had to use any. It's not like I don't drive in the rain, but every time I've pulled the rear pin, it's been corrosion-free. Still, others have reported that these pins seize so badly from corrosion they have had to saw them out, so it seems like a good idea.
I use synthetic grease, as for brakes, on the rotating faces, ends of bushings and lower pins.
Torque in the air. Don't crank down too tightly on the upper arm studs as it makes the suspension bind up. A good place for fresh lock nuts.
Yes put some antiseize on the pin.
I'm one of the few who had to saw the pin to remove it.
BADLY seized you say???
https://rennlist.com/forums/928-foru...s-are-out.html
