928 Forum 1978-1995
Sponsored by: 928 Specialists
MAF Adjustment ??
Old Feb 8, 2012 | 05:35 PM
  #31
jbrob007's Avatar
jbrob007
His comments did not fall on deaf ears! My car runs better than most, but this stupid vacuum leak was driving me NUTS! The injectors are next... right after I remove, clean, repack & reboot my CV joints... all four of 'em. As mentioned above, it wasnt 24 hours before I realized the passenger side CV boot was tearing (while replacing the Redline Synthetic gear oil with Mobil 1 LS 75W90 Synthetic) The good news is I caught the CV boot as it was starting to tear while up on the lift last night. The car is parked till I get to them.
BTW, I've heard that if you use the Redline Synthetic 75W90 gear oil that it will make your transmission & differential seals leak... The critics were correct as it started leaking (minor) within 10K miles I changed it out to Mobil 1 last night.
Thanks again to everyone for your help!!!
