928 Forum 1978-1995
Sponsored by: 928 Specialists
Tire Pressure - RDK
Old 02-03-2012, 03:39 PM
Bilal928S4
Bilal928S4's Avatar
Default Tire Pressure - RDK
I thought I should start a new thread after the tool thread to replace the RDK sensors in the wheels.
My rear tires end up being bald in the middle and still a little life left on the edges. This would mean to me that the tires are overinflated.
The Porsche recommended infaltion pressure is 36psi front & 44psi rears. This is what I run to keep the dash idiot light happy.
I read before that (wally's advice) that the car reacts and handles better with 36 psi all around.
So the question is can you take the front pressure sensors and install them into the rear wheels thereby reducing the rear required pressure?
I run standard size tires on standard 16" D90 wheels.
Old 02-03-2012, 03:54 PM
davek9
davek9's Avatar
44 PSI sounds WAY to high to me, when hot I'll bet they are nearing 50!
Old 02-03-2012, 04:18 PM
Alan
Electron Wrangler
Alan's Avatar
Originally Posted by Bilal928S4
...So the question is can you take the front pressure sensors and install them into the rear wheels thereby reducing the rear required pressure?
Yes you can -though defeating the system and replacing with a modern wireless programmable system might be better ( & perhaps cheaper). You can get a stem mount concurrent all 4 wheel pressure or temp readout system for a few hunded bucks - set your own alert thresholds for pressure & temp per tire.
Alan
Old 02-03-2012, 06:19 PM
Bilal928S4
Bilal928S4's Avatar
Alan, defeating the RDK system is just not true to the car. I want to keep it as stock as possible.
Also I read that if you defeat the RDK system by putting in the jumper, that also bypasses the antilock braking system or diagnostics.
Old 02-03-2012, 07:13 PM
Alan
Electron Wrangler
Alan's Avatar
It de-features the RDK diagnostics but has no effect on the ABS/PSD.
Alan
Old 02-03-2012, 07:15 PM
Alan
Electron Wrangler
Alan's Avatar
It depends - '94 & '95 GTS cars don't have it - so Porsche were the ones who evolved it away...
Alan
Old 02-03-2012, 07:20 PM
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,316 Likes on 497 Posts
It is just a question of time before you will by-pass the system anyway as you won't find tires for the rear pretty soon and will need to upgrade to 17", 18" or 19".
... Unless you put 245/50/16. Some does but not sure if I would...
Most of the 1994 and all 1995 GTSs didn't have it anyway!
Old 02-03-2012, 07:25 PM
DanielD
DanielD's Avatar
@ Bertrand: Goodrich is introducing a Potenza tire that fits our cars rears later this spring. This info is from he Goodrich rep at Porsche Palooza last November... They already have a size that fits the fronts...
Old 02-03-2012, 07:32 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,718 Likes on 1,319 Posts
The sensors don't know (or care) at which end of the car they're installed. The issue is finding an additional quartet of 2.5 bar sensors.
Bilal928S4
Bilal928S4's Avatar
My 90 S4 I have had for 11years and is my daily driver with 118k+ has working RDK sensors. Seem up be original. I hope I did not jinx myself.
Old 02-03-2012, 07:37 PM
Bilal928S4
Bilal928S4's Avatar
I have a set of my original manhole cover wheels that I just replaced with D90 wheels. So I have one spare set.
I also will be picking up a set of the cup wheels 17" this weekend. Keeping my fingers crossed that the sensors work on those.
damonoresky
damonoresky's Avatar
None of my sensors work, PITA. I think you're in the minority if you have a normally functioning system.
Old 02-03-2012, 07:42 PM
Rob Edwards
Archive Gatekeeper
The system on my GT has always worked perfectly. I don't keep the tires inflated to 36/44, so I get the warning every 25 miles or whatever the increment is. As little as it gets driven, it hasn't been worth it to jumper the connector.
Old 02-03-2012, 08:39 PM
Alan
Electron Wrangler
Alan's Avatar
Rob - I think the warning is just a 15-20 minute time interval.
You can always buy new sensors - 2 per wheel at about $500 each last time I looked....
Alan
Old 02-03-2012, 08:48 PM
Rob Edwards
Archive Gatekeeper
25 miles, 15 minutes, that's about right.
Quick Reply: Tire Pressure - RDK
