Navigation intall assistance needed.
Electron Wrangler
The reason they require it is so you can't just ground the wire to enable it all the time...
Alan.
PS did you see the new dual view screen - where on a single screen the driver sees navigation (for example) while the passenger sees a movie - completely separate streams on the same panel all based on viewing angle... the new Range Rovers have them - great use of dash space... I like this...
Alan.
Under the Lift
Yeah, I see they now have 2 wires and want to see a sequence of 12V on one wire, then ground on the other, then no ground, then ground, then no voltage on the first wire. Fascinating.
E-brake up.
E-brake down.
E-brake up. To be left there/engaged.
Last is foot off of the brake pedal.
Was a mess to figure out the first time. PITA actually because it is not explained in technical terms in the installation guide. I couldn't adjust the time on the headunit nor bass/treble, right/left, front/back
without getting into the advanced menu.
My head unit has rear outputs for other video but I am not using them. Those outputs function 100% of the time for back seat passengers. It's only the head unit that is locked out.
Michael
Hey Mcardenal - good timing. I'm starting to look around myself for a new head unit.
How up-to-date are the maps on the KD-NX5000? Looks like they are current as of 2008? Are you buying refurbished off of ebay?
Will it work with a JVC KD-NX5000?
