928 Forum 1978-1995
Sponsored by: 928 Specialists
Muffler Bypass for a 1983
Old Jan 18, 2012 | 09:30 PM
Bradster928's Avatar
Bradster928
Default Muffler Bypass for a 1983
After doing some research, I have discovered that a muffler bypass system will not work on a 1983. I am hoping for that same kind of sound, even though my 1983 sounds fairly decent now. After all, what's the point of having a v-8 without it sounding great?
Anyway, does anyone know why a bypass system is incompatible with the earlier cars?
Second, any suggestions on a great sounding exhaust, even if it is not a bypass?
Thanks!
Bradster928
Old Jan 18, 2012 | 09:40 PM
SMTCapeCod's Avatar
SMTCapeCod
You could leave the final muffler for the time being and install an x pipe and high flow cats to start- it will add more volume and better performance.
Or, you can have a custom exhaust shop fabricate a pipe to fit in lieu of the final muffler. No great shakes, the bypasses are a couple of bent/formed pipes/tubes.
Old Jan 18, 2012 | 10:16 PM
brutus's Avatar
brutus
Bradster the early cars the final muffler does about 75% or so of all the noise reduction so installing a straight pipe is usually too loud and obnoxious for most. That is especially true if you are running catless. Remember it is all too easy to miss the "european sound" and end up sounding like a rusted out old Mustang. Besides more noise is NOT more power just more noise and often gets you "attention" from the boys in blue ! Any exhaust shop could cut off the muffler and fab up a bypass just be sure they cut it so you can get it welded back on if you change your mind or wish to sell the car someday.
Old Jan 18, 2012 | 10:57 PM
Bradster928
Thanks guys. Good advice all.
Old Jan 18, 2012 | 11:12 PM
SMTCapeCod's Avatar
SMTCapeCod
I agree with Brutus' comments.
You could always just do this:
http://www.ebay.com/itm/928-Borla-Ex...item2317e503d8
928 Intl was a retailer, not sure whether they still have/stock them.
Old Jan 19, 2012 | 12:32 AM
vanster's Avatar
vanster
Interesting comments by all and I am perplexed as well
I just bought a Magnaflow which I am thinking of replacing the pumpkin with and eliminating the middle muffler, keeping a Magnaflow cat coming out of the MSDS headers thru a Y pipe. Not sure if all of this will work or what it will sound like.
Also has anyone had the system form the headers back welded up at the muffler shop off of the car?
Old Jan 19, 2012 | 08:10 AM
Ponty's Avatar
Ponty
On my 1981 non-S, I removed my rear pumpkin and had it replaced with just a tailpipe. So I still have front and mid mufflers, and that's it.
It sounds nice. Not loud on mine at all, in fact it's still muted until you rev it quite hard and then it sounds like it...
Mind you, I did have a rather bizarre tip welded on that I didn't notice at the time, and am now too embarassed to photograph!
Old Jan 19, 2012 | 08:35 AM
Jadz928's Avatar
Jadz928
Steve,
Since you just bought the car, my humble suggestion is to stay focussed on the mechanical end.
Base on the budget you mentioned, and having a shop do the work... you will use up all of that (highly likely, more) just to make the car operate reliably.
There are alot of fun things to do to these cars, but they eat up money (and your time) as well.
I would focus your efforts (outside of the shop) on the electrics. Big gains can be made there with low impact on your wallet.
Sorry to be such a buzzkill, just trying to help.
Old Jan 19, 2012 | 12:18 PM
Barry Chan's Avatar
Barry Chan
if getting the right sound for the car will inspire the owner to start R/R - may not be a bad thing!
Old Jan 19, 2012 | 01:37 PM
Strat_928's Avatar
Strat_928
I also have an 83 auto and my next step is to get the y-pipe from 928 motorsports and add either their high flow cat or a Magnaflow high flow cat. Leaving the pumpkin. My understanding is that this will tune the exhaust note a little closer the 32v models exhaust note plus increase the flow and a few hp's.
With the combo from 928 MS you should not have to make any modifications to the existing pipes either.
I think that will be plenty loud. I already have sound deadening in the rear floor and a 10 in sub in order to hear bass ! I mostly listen to the exhaust but on longer trips the music is a nice break.
Good luck!
Old Jan 19, 2012 | 02:27 PM
vanster's Avatar
vanster
If you notice the tips on the pumpkin come out more towards the side of the car
and many shops run the tips more straight back. I would think that to the drivers ear
you should pay attention to where you route the tips. My guess is Porsche ran the tips more to the side to appease the driver as well as keep the sound legal. Remember Porsche was wrestling with the Feds on sound in the mid 70's with the 911's.
One of the reasons for a water cooled motor
Old Jan 19, 2012 | 02:38 PM
z driver 88t's Avatar
z driver 88t
The exhaust on my car is on my to-do list probably for 2013 (have other projects in higher priority).
I've done a lot of forum searching on this and it seems like the best overall exhaust set-up recipe for normally aspirated 16V cars is are the 32v manifodls (or MSDS headers), y-pipe, and single 3-inch exhaust with a flow-through muffler (like Magnaflow). This is the route I will probably go since the PO already had the 928 Motorsports y-pipe on the car when I bought it.
But there has been very little posted in terms of before and after dyno testing with specific setups.
Also, when I've fabricated exhausts for some of my other cars I've usually bought aluminized exhaust mandrel bends from JCWhitney and been able to piece together a decent mandrel bent system. You can also buy them from Jegs, but JCW was a little less expensive. Good quality pieces too - no issues with that method. It really seems to be the only option on 16V cars since there don't seem to be any good aftermarket systems for the early cars anymore.
Old Jan 19, 2012 | 03:05 PM
911tracker85's Avatar
911tracker85
I recently posted a thread asking for advise about 16V and headers. read lots of threads but all the real advice was for 32V cars. basically headers/exhaust mods on a stock 16V may only get you 15hp. now if you put on a SC, need to open up the exhaust to get all that extra volume out the back to avoid too much back pressure. also some comments about the more you open up the exhaust on a 16V you may loose some low end torque but gain HP in the upper RPM range. from talking to one supplier, due to the limited benefits the 16V crowd are not inclined to spend much on exhausts so a lack of incentive to invest in offering the range of options as for the 32V.
I cobbled together a CAT back for my 84 last year. I got a Y from Roger to replace my CAT due to exhaust leaks. results were a bit loud but the big issue I encountered was the sound. seems the pumpkin baffles had rusted out, even though no leaks. all I can say is my exhaust note sounded like it exited through an empty garbage can. replace pumpkin with small aftermarket and the resonator with a round magnaflow. now great sound.
PS. tacked on my pumking heat shield to prevent damage to the bumper cover.
recently got a set of MSDS headers to install this winter. I agree with Chris, seems the best suggestion for 16V cars is 85/86 or header into a Y then 3" all the way back.
going to get the headers installed and collectors to figure out how to fab the rest.
good luck to ALL of us in our quest for more HP and great sound.
File Type: jpg
Old Jan 19, 2012 | 05:23 PM
G Man's Avatar
G Man
I had a roommate at one time that had installed supertrapp's on his Ford truck. Had a really nice sound.
