928 Forum 1978-1995
Sponsored by: 928 Specialists
Oil Level Sender = how does it work?
Old Jan 14, 2012 | 11:48 AM
heinrich's Avatar
heinrich
928 Collector
Default Oil Level Sender = how does it work?
If the tip of the sender grounds, I presume it will defeat the sender?
Old Jan 14, 2012 | 12:04 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
the float drops then connects the two metal connections on the arm this triggers the light.
why would the tip be grounding?
its held in suspension?
Old Jan 14, 2012 | 02:36 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
The ones I have seen have a float around a bulb in the center that to be some kind of magnetic induction switch. I have not seen contacts on the arm.
Old Jan 14, 2012 | 02:59 PM
heinrich's Avatar
heinrich
928 Collector
I ask because (Stan) the tip of the arm is soldered, and with the new ob metal screen (which is bolted to the pan) there will be a clear electrical connection all along the tip through whatever it connects to on the other side. It occurs to me it should be insulated, but I guess we will see. I can prolly just do a quick resistance check. No friggin idea how I would reliably insulate it, but thankin God, at least it can all be done through the opening from the outside, since it is all together with spacer etc.
Old Jan 14, 2012 | 03:41 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
a picture of what you have would be helpful here,
but the wire runs down the inside of the arm.
THE outer area is grounded to the pan
Old Jan 14, 2012 | 05:46 PM
heinrich's Avatar
heinrich
928 Collector
Originally Posted by Sterling
you need to get the OB oil sensor that clears the screen. Problem solved.
606 301 02 ... same part. In 88 they went to 03.
Old Jan 14, 2012 | 06:09 PM
heinrich's Avatar
heinrich
928 Collector
OK, tested ... it's a very simple contact mechanism. On or off. At the lower end it groumds the wire/pin and worns. Just filing the tip a little has allowed it to clear, so I am fine . No shims needed.
