Towing eye thread cleaning tap useful ?
#78
#79
Electron Wrangler
Alan
#80
Electron Wrangler
The tap is expected back in next 2 days from Andrew - so Ivan (Whitesands) you are on deck next - check your PM
List is currently: (if you are on this list I have your details no action needed to stay there).
1 CraigL (St. Louis) -> $50 Rcvd - Tap Sent 2/7/2012 -> Delivered 2/10/2012 -> Craig $32.20 (gross) refunded to your Paypal.
1a byrdman454 (St. Louis) Sent Back 2/21/2012 -> Rcvd 2/23/2012
2 AO (Nr. Detroit) - >$50 Rcvd - Tap Sent 2/26/2012 Expected back iminently
3 Whitesands (Florida Panhandle) Next Up
4 90 S-4 (OC - California)
5 jthwan22 (Central NJ)
6 auzivision (Indianapolis)
7 Donald (Houston Area)
8 shadowknight (Clearwater FL)
9 fraggle (Northern VA)
10 cold_beer839 (Nr. Raleigh NC)
fraggle you are added, cold_beer839 you are added too
Not sure if you need this ? - go out & see if you can remove your front towing eye bung - don't wait till you need it in an emergency...!
Folks - please try to set up group use session if possible (local gathering etc), Please take pictures & make notes on results & techniques - & post back here...
Alan
Alan
#82
Electron Wrangler
Status Update:
1 CraigL (St. Louis) -> $50 Rcvd - Tap Sent 2/7/12 -> Delivered 2/10/2012 -> Craig $32.20 (gross) refunded to your Paypal.
- 1a byrdman454 (St. Louis) Sent Back 2/21/12 -> Rcvd 2/23/12
2 AO (Nr. Detroit) - >$50 Rcvd - Tap Sent 2/26/12 Rcvd 3/24/12 Andrew $32.20 (gross) refunded to your Paypal.
3 Whitesands (Florida Panhandle) >$50 Rcvd - Tap sent 3/26/12 Rcvd 4/06/12 Ivan $32.20 (gross) refunded to your Paypal
4 90 S-4 (OC - California) $50 Rcvd - Tap sent 4/7/12
I have modified the packaging a little, have added a details card and the tap is directly labelled per previous suggestions. Until now the original box has just been reused. Time for a new one - packing is holding up well though!!
Alan
Alan
#83
Electron Wrangler
See this thread for details on using this tool by Ivan (Whitesands)
https://rennlist.com/forums/showthre...eferrerid=6055
Alan
Alan
#84
Electron Wrangler
4 90 S-4 (OC - California) $50 Rcvd - Tap sent 4/7/12 -> Delivered 4/9/12
- 4a Rob Edwards (Irvine CA) Sent Back 4/11/12 -> Rcvd ...
5 jthwan22 (Central NJ) James you are next Up
Alan
Alan
#85
Electron Wrangler
Just a note here - since 2/7 when this first shipped out - we've had six 928's get repaired in just over 2 months!! great going, rather faster than I expected - largely because we've had 2 case of 2 getting repaired for one shipment - efficient!!
If you are on the list and have local 928 buddies ask them if they need this - and if they don't know - have them check...
Alan
Alan
#86
Archive Gatekeeper
I have been working (playing?) on Dan's green car this week- literally as we were looking at Dan's seized tow plug, I got an e-mail from Joe saying that the tap was in town and did I need it? Picked it up the next day, and liberated Dan's old plug. Joe suggested a 21/32" drill bit- that plus a die grinder with a cylinder-shaped carbide burr plus the tap (and liberal cutting oil) worked a charm:
#87
Just to easy, I got home from work on Monday to find the tool
had arrived, opened it, 10-min later I was done.
All the work was in prepping the hole, I predrilled with a 21/32
That left the remaining material paper thin, the tap blew right
through it.
Thank you Alan & Thank you jpitman !!
through it.
#88
Electron Wrangler
4 90 S-4 (OC - California) $50 Rcvd - Tap sent 4/7/12 -> Delivered 4/9/12 Joe $32.20 (gross) refunded to your Paypal
- 4a Rob Edwards (Irvine CA) Sent Back 4/11/12 -> Rcvd 4/13/12
5 jthwan22 (Central NJ) $50 Rcvd - Tap Sent 4/13/12 -> Delivered 4/16/12
10 Ed Scherer (Nr Kansas City)
Alan
Alan
#90
Electron Wrangler
Do you mean an allen key is broken off in the plug?
Is it broken ~flush with the surface?, can you grab it to wiggle it out (lubricate it first) ...
Alan
Alan
