Engine sat -> gelled fuel
928 Collector
My fuel rails contain goop from sitting. Is there something special I need to do? It seems liquid and fluid at this point, not crystallised, but it sure is thick. Should I just try to run it through the system when I start, or should I try to clean it, and if so what with? We're talking rails; dampers; fpr; injectors.
Hmm
I'd pull the injectors and send them out to witchunter for cleaning-balancing.....the clean the rails (not sure with what)...do the same for the dampers-regulator...
Sharkaholic
Buy a couple cans of Seafoam fuel treatment, use one to flush the rails etc with and the other put into your gas tank with some fresh fuel.
Suggestion
Had the same issue on a bike a few years ago, and the "fuel flush" worked for me.
unfotunately It is going to be really difficult if not impossible to clean the regulators well... the air pressure or chemicals needed to clean them will damage the diaphrams....
928 Collector
Former Vendor
Blow it out. Use some spray cleaner....just about anything will work. I wouldn't use spray carb cleaner...pretty nasty stuff. Acetone would work great...most California brake cleaners are now mostly acetone.
Apply 12 volts to each injector and make sure the solenoid works...you will be able to hear them "click". If they don't click...tap gently on them, until they do. Keep hitting them with voltage and then remove the voltage until the clicking sounds the same. This will "free" up the solenoids.
Blow backwards through the open injector with compressed air...crap will come out...watch where you point the open end (not toward eyes).
Spray through the injectors...backwards with them open, at first. Then normally.
Injector guys can't do anything to "balance injectors". They can only clean them and test them.
Install and run the engine. Check the regulators and dampers for leakage into the vacuum system carefully. Current fuels "disolve" the diaphragms. Old fuel is really hard on them. Most all will leak after sitting for any period of time.....many leak just from age. A new set would be money well spent.
928 Collector
Thanks Guys. The car was driven this year, so all fuel components are good. On the replacememt engine, there are very few and easily accessible components.
