question for you brake rotor guys
my rear rotors have just about 2k on them... and I'm wondering while I'm doing my trans work, if i can get them yellow zinc plated and then just wear the coating off...... i hate rust..
Archive Gatekeeper
I had a set of rotors done in bright zinc, and theyr'e still blingy looking, but when they were bedding in there was clearly material transfer onto the pads, and during that time braking performance was definitely affected. I think I'd just take your rotors, tape 'em off, and hit them with gray VHT paint.
Plated:
![](https://webfiles.uci.edu/redwards/public/Bright%20zinc%20plated%20rotors.jpg)
Taped:
![](https://webfiles.uci.edu/redwards/public/Rear%20rotors%20prepped%20for%20paint%207-4-11.jpg)
Painted:
Plated:
Taped:
Painted:
![](https://webfiles.uci.edu/redwards/public/Hebert%20rear%20brakes%20done%2011-18-11.jpg)
Be careful of layers of paint on hat inner and outer faces. After you fit the wheel on a recently painted setup you can have the paint soften and act as a lubricant, and cause issues with rotational slop if you don't re-torque soon after the first few heat cycles. The problem is worse where you have two painted smooth surfaces together, and less of a problem where you have annular machining marks on the inner wheel face, because it will push through the paint layer to the hat.
Chronic Tool Dropper
I used some CRC "instant cold galvanizing" spray on the rotor areas that weren't already galvanized. mainly the finned areas and insiode of the hats. Masked the friction faces as Rob shows. Once dry, I painted the outside exposed area of the hats with wheel silver, then a few layers of clear. I know the zinc spray will be fine. Worried more about whether the hi-temp clear will hold up without yellowing or scorching from the heat. Won't know for a while since I so seldom use the brakes.
Mark--
The discoloration is a telltale ign of hard spots that make resurfacing really tough. While they might have been turnable on a standard brake disk lathe, they are now doomed to a life of grinding for any refurb. No wonder you are trying to get $13 rotors to fit!
The one on the left looks like it was just blasted and needs an initial protective coating.
