928 Forum 1978-1995
Sponsored by: 928 Specialists
Is the power steering pump done if growls when cold?
Old 01-08-2012, 03:52 PM
Captain_Slow
Captain_Slow's Avatar
The job was really easy until it came time to put that long bolt back in. No way to see in that hole to check alignment. I ended up getting it lined up after about 20 minutes of trying -- but using a piece of stiff wire as a feeler. I could determine if the holes were lined up by feeling for a catch pushing the wire in and pulling it out. I did this at the top, buttom, left and right positions in the holes until I could feel they were were perfectly aligned....then I put the bolt in on the "first" try (after getting the wire idea).
Quick Reply: Is the power steering pump done if growls when cold?
