gas smell
Hello again , this time im looking for advise , today I took off the wooden fuse cover and noticed a wire that was cut somehow. I. Emailed the previews owner and he said that it's the oxygen sensor. Also recently my car while driving smells like gas , is it running rich because of the cut? Fuel pressure while idling is around 34psi jumping. Also how can I fix a shielded wire? Check out pics !!!
Well...thats gotta be fixed...Im not the expert on that, or much else, but lets start at adding the year/particulars of your car in your signature..like down below. Then we know whats being worked on.
Idle could be many things, what year car?
Team Owner
to make changes to your signature.
first go to the top of the page click on user CP
then click on edit signature,
then add the info about your car year make model trans mission, and any other option you might like to include,
then click on save
Remove the right front wheel then the fender liner then look under the black cannister in front of the washer tank see if the 3 hoses are connected to the 3 way connector this connector usually breaks and then causes a fuel vapor smell.
Also inspect your fuel lines see if there is any wetness around any of the junctions this will require removal of the lower half of the aircleaner to inspect the hoses dont keep driving the car till the fuel source is found.
For the wire this goes to the computer connector the wire can be replaced from the computer to the O2 connector
it will be a bit of work to do 928 INTL may have a used harness that can be used to get this wire from mention the half price sale
then click on save
I have 3 mile to get home and start checking , can I make it with out blowing up? I drove like this with that smell for 4 days but the uneven idle started today
Hey guys before I drove that 3 miles I checke the car before driving and found that this hose that connects to lower intake thing was off soni put it on and drove and didn't smell gas. And ran better too I think, would that be it ?
Team Owner
no thats a feed from the air pump ,
best to follow the instructions posted for finding the fuel leak/ smell
Ok , I put a clamp on the air pump hose , but I did lock my keys inside the car ! And I only have one key! Do you guys know if I can buy one at dealer with the vin number ? Any tricks how to open the door ? I have the hood opened but I don't think that helps ... Man bad day ...
