View Poll Results: Replace 60k porsche water pump with Laso or let it ride
Keep Porsche water pump
7
18.92%
Replace with Laso
30
81.08%
Multiple Choice Poll. Voters: 37. You may not vote on this poll
Porsche Water Pump with 60k change it or let it ride
I wouldn't buy a used water pump, not even if it was just a year old, but I HAVE left on a water pump that looked good during a TB change. I would not do it again even on a non interference car. My reasoning was leaving it on was worth the risk vs broken bolts etc from taking one off.
Under the Lift
I have no problem leaving a good 60K mile water pump alone, but not one from 1989. Your 89 sat so much, I'd be real worried about a lot of engine parts, especially if the coolant went unchanged for many years. I'd want to take that water pump off and examine the cast iron impeller, so you might as well change it.
When I bought my 83 five years ago, it had 60K miles on it. I changed out the original TB and inspected what I could of the original WP. without dissasembly. The car has run another 60K miles on that pump without any issues. When I replace the TB this winter I will replace the WP w/120K miles on it.
Water pump is out, looks good and feels good, but will be replacing with a new laso from Roger, the impeller is metal on the original pump vs plastic on the laso.
