View Poll Results: Did you remove your Fuel rail gauge?
Never had one
40
46.51%
Im keeping it on there
15
17.44%
I am removing it, and use for testing only
31
36.05%
Voters: 86. You may not vote on this poll
Fuel Rail Gauge .. removed?
I just swapped out my fuel rail gauge it has been in service for about 5 years the inside oil has turned a darker shade of tan but it has not leaked , i got from summit racing.
I installed the correct cap and ball.
Just wanted to see if anyone else is gonna keep the gauge on the engine or remove and use for testing
I just installed a sensor in my car (ordered before the thread started), and put a gauge in the car.
However on my other 928 I will leave it in there. I will however replace the gauge once every two years or so just because.
I've never considered installing and leaving one on. My GT engine came with one of Roger's gauge kits. I'm going to talk with Rog and figure out how to deal with it but I'm thinking to remove it.
I've never figured out why people need this information....so I've never used one, personally.
If I need to know the fuel pressure, I hook up a 4" certified gauge that is accurate within a half of a pound...at the worst case. I set the fuel pressure where I want it (in the cases where it is adjustable) and forget it.
In the cases where the fuel pressure is not adjustable....I have even less need for a permanent gauge....what the hell am I going to change if I don't like the fuel presssure?
Those cheap little gauges can be off as much as 10 pounds....I can guess the fuel pressure closer than that.
I used mine to trouble shoot my fuel pump / rough running issues, I left it on.
However, I have now removed it and replaced with the the ball and cap.
Now, i'll need to get a new fuel rail cover as mine has a section out the front
The remote gauge is obviously a better way to go as you can sit in the car and view it..but as far as a leak source, its only as good as the job you do installing the remote sensor on the rail. I also am curious as to the cause of Randys fire...Gauge...or tapped rail nut with teflon tape..or rated paste?
In the cases where the fuel pressure is not adjustable....I have even less need for a permanent gauge....what the hell am I going to change if I don't like the fuel pressure?
I also got mine from Summit Racing. I'm wondering if there's any real differences between the vendors/guages. I.e., I noticed Carl still has his on the 928 Motorsport site and it says:
The Kit: We provide you with a high-quality glycerine-filled fuel gauge that you can permanently attach to the fuel rail with the fitting supplied. This special fitting has the correct metric threading on one side, and the correct gauge threading on the other. An O-ring is provided for a positive seal. Gauge does not require any wiring, and is HD industrial grade, durable and designed for years of use.
I am leaving mine on all my cars. As of today I am not comvinced it was the gauge that failed. However for saftey sake I have removed my kit from the market unless it is used for testing purposes only.
Having talked to the various gauge manufactures about different specs for types of gauges for our application in the less than $50 range they are all the same. Defined by diameter, connection size and position, pressure range, color of gauge, metal or plastic. Bourden material seems to be the same in all at this price. All mine have been filled with either glycerine or silicone to dampen the needle occilations. Most will not spec for gasoline for liability reasons. Unless the medium being tested is corrosive all liquids will work.
About seven years ago Jim Mayzurk, Ernie Swersky and myself drilled and tapped the original cap on the fuel rail and attached a pressure gauge that we bought from Grainger for about $8. Mine is still on my car today and so is Jims. Sounds like Ernie's is still there as well H. 928sRus was still a twinkle in my eye at that time.
Judjing by how many use a fuel gauge on the car relative to the number of reported failures - a very safe product. A lot safer than water pumps!!!
If you prefer to keep the gauge on the car then I would recomend changing the gauge and checking the connection every couple of years. Gauges are cheap relativly speaking (Autozone sells for $9.95). Better to be safe than sorry.
