Powerdyne SC Kit FS
Thanks Carl.
Been getting few questions. The Powerdne head was upgraded with the impeller, belt and bearings so it could make more boost at lower RPM. The impeller was shimmed .006 to the housing. Head will not fray the internal belt or encounter bearing failure. SC is not driven into overspeed and was purposely built to run constantly at high impeller speeds . This unit will add 100-120 HP.
- 100% bolt on, your not making or fabricating anything. You can tune it in your driveway no need for a dyno. I'll inform the buyer what timming and fuel pressure settings made the best HP off my 4.5 and 5.0 engines dyno tests.
- L-Jet can easily fuel the SC. No need to change the injectors. Do need BEGI or any FMU.
- I added an second SC belt tensioner. (not shown in the first pic) SC belt does not slip.
Wow, very tempting! Are special headgaskets required? I just had my heads recondioned. Engine has less than 100k miles on it. I understand the intake plumbing needs to be custom made? What else is needed?
Developer
It might help for you to read about the kit and see some pictures of it installed.
Here is the link: http://www.928motorsports.com/parts/stage1.php
Ad van der Lee stock head gaskets are all I use, no re-torquing
The charge tubing is available thru ebay or your local speed shop. nothing special just bolt on.
Fuel system needs metric to AN fittings, then make or buy -6 an fuel hoses.
If you don't want to make the fuel hoses, Carl offered to sell pieces from his stock, that very generous of him because he would be breaking up a kit.
Craic Head
Craic Head
