928 Forum 1978-1995
Sponsored by: 928 Specialists
strok question
Old Dec 12, 2011 | 10:18 PM
  #136
EspritS4s's Avatar
EspritS4s
Good luck with the build!
Old Dec 13, 2011 | 12:43 PM
  #137
terry gt's Avatar
terry gt
Ok , I get it ! its not the gap diff on the pin end that you see that matters , its the center of the rod beam that is wrong . And causes the rod to flex sideways . When the rod flexes the piston tilts in the bore and wears . Anyone want a set of 5.85 oliver rods ? Matching set / new bolts ? Sold to me by Mark A.
Old Dec 20, 2011 | 02:44 AM
  #138
terry gt's Avatar
terry gt
Here is a picture of a failed stroker using chevy rods . the piston coating failed . So if the rod offset is so bad why dosent the scoring pattern indcate a front-rear issue ? About 10k on the motor.
File Type: jpg
File Type: jpg
Old Dec 20, 2011 | 02:53 AM
  #139
Speedtoys's Avatar
Speedtoys
Obviously you can screw up an engine in more than one way..
Old Dec 20, 2011 | 03:06 AM
  #140
Speedtoys's Avatar
Speedtoys
Correct, kinda.
Its the center of the rod beam that is wrong
Nope.
Kinda, but not really.
Turn that around into "The piston pushes on the rod off center, and flexes the rod" and you're good.
A rod is an Ibeam...for the most part.
Theyre strong as heck in a straight line along their length in this configuration. They dont take Lateral-torsional loads (from the side), but only concentric axial loads..I think?..me and kollege didnt do well.
Not so much if loaded off center. It'll bend.
Old Dec 20, 2011 | 03:48 AM
  #141
Fred2746's Avatar
Fred2746
Cruisin'
I don't know what a K1 rod is but assuming it's a modern Chevy rod, it's symetyrical and what you are seeing is the difference between the cylinder bank offset and rod width. The rod would be offset in the piston by about .5mm which looks to be about what you have going on there.
Why do you say it's asymetrical?
Old Dec 20, 2011 | 05:08 AM
  #142
danglerb's Avatar
danglerb
Maybe its rockit science?
Old Dec 20, 2011 | 05:29 AM
  #143
Speedtoys's Avatar
Speedtoys
I think that a loose pinch bolt on the back of the torque tube, is what caused those rods to bend.
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
