Suicide!!!
#31
Under the Lift
There's nothing other than the jump post cover on the passenger side near the coils, and I can't recall seeing anything else there on other cars. The only other trim pieces I have are forward of the radiator and are there to help prevent the air coming into the nose from escaping from the radiator area. I can't find anything else in PET except "gasket lateral" shown below. PET appears to indicate 2 pair for 88 and before, 1 pair for 89 on. Anyway, that's my interpretation. Are these it?
#32
My car has these on both sides. I call them weatherstripping rather than trim pieces.
Trim indicates a cosmetic/aesthetic use. These are there to keep water from entering the engine compartment, so they are not cosmetic.
#33
Under the Lift
Yes, I have those but they are nowhere near the coils. And my guess is they are there to seal off the nose air. Regardless if that's what Wally means, OK, I have them , but I can't see how they keep water off the coils. If anything, they would channel it up fender lip closer to the coils. I was interpreting his comment as indicating something above the coils. From my last pic of the left side coil, you can see it is pretty exposed.
#34
Received 1,553 Likes
Let's be precise: The ignition monitoring system is triggered by a difference in cylinder temperatures across the block. It's purpose is to detect ignition problems, but in practice anything that can result in a cylinder not firing well can trigger the IMS. So, besides ignition problems, the IMS can trigger because of a faulty injector, super-bad carbon buildup, a combination of component failures, etc.
Try a bad o2 sensor an out-of-spec MAS and a couple of dirty injectors and see what happens...
#35
Before you have serious issues
fonetico,
Remove the small carpeted cover from the right kick panel, and put it in the rear floor. Find the clear box at the end of the bracket holding the ECU's.
The next time that the car runs poorly, with the engine still running, look at the box and see if there is a light inside. If the car runs perfectly for several trips, put the cover back on.
The rough shifting is probably because you are using more throttle, since the engine is way down on power. The transmission thinks that you are at full throttle, so it will shift late and hard - as designed.
#36
Hmmmmm
#37
#38
Rennlist Site Sponsor
I have been trying to think of a clearer way to describe these...
"It's a trim piece, (my terminology, not Porsche's), not a seal. Just a little clip-on piece of trim on the edge of the fender to deflect the rain/wash water where it normally spills off onto the coils. "
Perhaps, "The little black pieces on the right fender edge just above the coil in the bottom photo in post #37."
There should be one on each fender edge.
#39
Under the Lift
Dwayne:
Aha! I can't say I ever noticed those on any other 928. You've got them on 3 out of 6. They must get knocked off rather easily as my car was previously owned by one of the most compulsive 928 owners I've ever met. - even more compulsive than you - but they were gone by the time I got the car. I'll pick some up at Sharktoberfest if i can figure out what PN they are.
#40
I had this problem, I traced it down to a distributor cap contact being worn.
It took a while to track down and by the time I had finished I had replaced the coils, rotor arms, plug leads, sparkplugs, distributor caps and added a fuel pressure gauge.
To cut a long story short, I ended up checking each plug on the side that the relay was telling me there was a temp difference, noted which clydinder was not firing by condition of the plug. Traced this back to the cap, looked at cap and replaced cap, sorted.
#41
Under the Lift
Easy enough to check - pull back the carpet in the passenger footwell to expose the clear relay box and and start the car.
#42
Archive Gatekeeper
I have an IMS error on my GTS, kept tripping into 4 cylinder mode. Did all the testing and concluded that I have a dead sensor on one side or the other. But I can't reach them with the new headers in the way, so I have it jumpered.
#43
#44
Well, to conclude my brief episode, it seems that the world's in order again.
I've replaced the coil and HT lead and so far the engine is back on song.
I don't know whether it's my paranoia but I think I had a brief moment earlier where it felt as though it was stuck in second gear for a few minutes. I was navigating heavy traffic and it could just have been my imagination.
Will this be the next project? There's just no respite!
My first serious car was a 924 that I had for twenty years and ran up 300k on the clock. Apart from brakes and rubber, the only problem it ever had was a snapped clutch cable. Oh that the 928 were that reliable!
