2nd to 3rd shift flare " Fixed so it seems for now "
There can also be a B2 piston issue that might be bit related to this. The outside edges of my B2 piston were skuffed and it was sticking during the shift from 2nd to 3rd. Sometimes it would just totally stick in the middle and I would basically be in neutral. New B2 piston solved it.
Put in the K1 spring kit from Roger today and did the task of filling the fluid back up. After a short test drive the transmission seems to shifting like new, the spring is much heavier than the one that was in the transmission. After the test drive the fluid was at the minimum mark on the view glass so I will add some more in the morning and give a longer drive. Not a hard job to do at all, would have been alot easier with a lift instead of the floor but thats all I have. Thanks, Jack
