928 Forum 1978-1995
Sponsored by: 928 Specialists
928S with 4.5L engine ...does it exist ???
Old 09-06-2011, 12:21 PM
  #31
Pfunde
Pfunde's Avatar
Did this 5 yers ago. Engine was 2000 euro, 1000 euro to change it and thy kept my old 4.5 as part of the deal......
Old 09-06-2011, 12:39 PM
  #32
GerritD
GerritD's Avatar
Cool
Nice..... well for about 3000 euro (incl working hours) I would like to do the job.
I check in Belgium and in Germany and they offer engines for about 2500 euro...so it can be done.
Old 09-06-2011, 12:43 PM
  #33
Pfunde
Pfunde's Avatar
Took 2 days...... I dont know if you need special engine for aut. Trans. Someone here at rennlist will know. I know my engine came from a aut. Tranny car . I think its 28.12 and 28.11, one is aut other is manual
Old 09-06-2011, 02:58 PM
  #34
Vilhuer
Vilhuer's Avatar
Originally Posted by Strosek Ultra
The car is a 1980 928S which came with a M28.11 221 kW (300 HP) engine and a G28.05 5-speed transmission.
As mentioned by others it is now and was automatic when it was new. PET lists it as automatic with M249 option code.
There really isn't much difference between automatic and manual engines. Mainly vacuum connection to intake. So manual 4.7L S engine will work and current 4.5L has probably all automatic gearbox related parts which can be used again.
Old 09-06-2011, 03:07 PM
  #35
GerritD
GerritD's Avatar
thanks for your extensive research, guys. I'm feeling a lot more confident for replacing the engine now. Would you advise are rebuilt engine (is ofcourse a lot more expensive) or just a used but good engine with not too much milage ....
Old 09-06-2011, 03:41 PM
  #36
karl ruiter
karl ruiter's Avatar
I bought an motor out of an S car that had been brought into the US. At the point that I purchased it, it had a US 4.5l block, but a 4.7l Euro S top end (heads, cams, intake, etc). I assume there was an issue with the short block so it was swapped out. I suspect there is a good chance that this happened to your car as well. Most of the difference between the Euro S and the 4.5l motor is in the top end, so I really cant see why anyone would swap the whole motor when the they could just swap the short block. So, I would suggest that you take a careful look at what you have before you make any big changes. I don't have dyno numbers on the 4.5 short block, Euro S top end combo, but it is pretty nice at the seat of the pants, and if this is what you have it might not be worth changing your motor. If you post pictures of your motor we can tell if you have a Euro S intake, at least. The heads you will have to check by part number.
Old 09-06-2011, 04:24 PM
  #37
danglerb
danglerb's Avatar
Start with pictures and more ID numbers, casting numbers on intake runners and heads.
Changing engine and transmission seems odd. Does it have a instrument cluster for an AT with the gear selection I think in the lower part of the tach?
With a used motor, even low mileage, its still 28 years old or more, I would pull the heads and have them refreshed and reseal the whole engine as well as checking bearings and rings for wear.
Did the early Euro S get the higher stall torque converter?
Old 09-06-2011, 04:32 PM
  #38
GerritD
GerritD's Avatar
Cool
Karl, I'll get back to you after 2hours since I'm still at the office and all my pictures are at home. Hopefully I can find enough information such as head part numbers.... already thanks
Old 09-06-2011, 04:40 PM
  #39
GerritD
GerritD's Avatar
Question
Early euro clusters do not have AT indicator (only for later 4speed ATs)
What's a stall torque converter and where is it located ?
Old 09-06-2011, 06:58 PM
  #40
GerritD
GerritD's Avatar
Wink
these are the only photos I have :
Hope this helps a little bit
Old 09-06-2011, 08:19 PM
  #41
karl ruiter
4.5l non-S intake, I think. So I would assume non S heads and cams also. Looks like there is a motor sway in your future. Sorry.
Old 09-06-2011, 08:25 PM
  #42
GerritD
GerritD's Avatar
I suspected that :-( .. but hey this gives me the opportunity to check and arrange my engine and AT properly so that I'm sure everything is in good order when cruisin' on the German and Belgian highways :-)
Quick Reply: 928S with 4.5L engine ...does it exist ???
