Cam timing effects, 32V
#121
#122
Sean: There is another variant that can take this topic to the "abyss"... that is that if you have aftermarket or reground cams, you need to verify the lobe center angles with a degree wheel to "calibrate" this tool before you know the "zero" for the installed cams. Once "calibrated", it's a great tool for tuning !
#123
#124
Gregory would be very happy to hear we took a look at the timing. ive checked all i can and im not about to pull cam covers on any car but mine and maybe yours!
#125
smart guy, with shaved heads things get a little off. we found this out when i was doing the tests on the holbert engine. ALSO, if you remember Ken and I were in a heated battle for how i was tesing the cam timing, as i repeated my process, i took a short cut on the starting position of the crank, rather than the full two revolutions, i started it at 2 revs yes, but didnt keep the dial indicator connected as it was getting in the way on rotation. so, i was getting a pre-moved value on the lifters. fortunately, my values were never that off, because i had always used that technique and matched the values when installing or adjusting the cams. in the end, the porken tool was pretty accurate and we ended up using the cams at the same 8 degrees retarded setting for the intake cam. (cold)
#126
#127
Inventor
With more retard, there is less dynamic compression, so more ignition advance can be used w/o knocking.
Doing this leaned out the AFR for me, either by burning more, or by being less efficient (more fuel just passing through unburned), so I also had to add more fuel.
The combination of more fuel, and more ignition advance more than makes up for the loss in compression, at least with S3 cams.
I really didn't lose much torque at all, but gained a lot of HP, and it really loves to stay rev'ed. It doesn't 'feel' as though it has much power down low, but it has basically the same HP at lower rpms - it just has so much more up high, so I tend to keep the revs high. 4000 rpm feels effortless.
Another thing I did was disable injector cutoff, which helps keep the engine at high revs, even if you let off the throttle for a moment. It also makes that racy, snap, crackle, pop on decel.
yes, i was able to jump 4 full teeth and not hit, but that is expected, since the cams only move the valves, .2mm with 20 degree crank movement.. the valves try and chase the pistons, but never catch up unless you skip a couple of more teeth. my car ran with 3 teeth off, but it was the worse running car you could ever imagine!
Put in a PKT, yet, BTW?
From my results I'd postulate (pontificate) that you'll probably be better off retarding the cams, and adding a bunch of ignition advance down low, instead.
Do you have a knock sensor installed?
#128
Inventor
Another tidbit I forget to mention (it has been mentioned by others, too, I believe).
Advancing makes the exhaust note quieter.
Advancing increases engine braking.
Advancing raises the idle speed.
Retard makes the exhaust note louder, sometimes unpleasantly so.
Retard decreases engine braking.
Retard lowers the idle speed.
My '86.5 auto, with +3° advance is unnaturally quiet with X-pipe, dual '86.5 (=GTS) resonators, and modified pumpkin, even at full throttle.
If I'm thinking about this correctly, another way to do -8° retard, or more, would be to rotate the engine CW to the 1|0 mark on the balancer after T|0, then use the 32V'r to advance to the desired setting, EG. -10° + 2° = -8°. (0° on the 32V'r becomes -10°.)
If you want to go big, 10°+, and there is not enough slot to allow this, you can restring the belt over the cam gears one tooth (7.5°) retard, then use the 1|0 as 'zero'.
First, I'm going to see how much more I can get in the slot on my '86.5 5-speed, then maybe restring.
#130
#131
Inventor
Setting it to 1|0 worked great!
The 1-4 max'ed out at -16°. Tough to turn the top screw, so I set the 1-4 to -14° cold, for a target -12° for both sides hot.
I bumped up the ignition timing a bit more, but haven't had a chance to log it for AFR, yet. It has not lost power, at least...in fact it keeps pulling all the way to 6700 rpm.
#133
Ken, what kind of results do you predict from this on the street? Is this something I should be looking at on my setup? Still waiting on the x-pipe though they say it is ont he way. I am going to the paint shop today and see what the chances are that you could put a satin topcoat over the standard Schwartz black finish. That with black chrome phonedials should look pretty awsome, I think?
Keep up the good work. I almost have my 1000 miles so that I can start messing with the timing. Car is running just awsome. I can't find enough excuses to drive it though.
#134
Do we also have any idea what retarding the cams this much does to emissions? In my case, I need to pass every year. Just passed again this year with flying colors. 4th year in a row with X-pipe, high-flow cats and a supercharger. My cams are currently set to stock.
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
#135
Inventor
Brian - more HP! Not sure yet how it will work with an auto, though. Will probably have to adjust the Bowden cable for higher rpm shifting.
Dan - NOx emissions may be lower? MPG might go up on the highway?
I have increased the idle ignition advance a touch, because the idle has lost some of it's S3 smoothness. Oddly, low speed (<2K) torque is still good. The exhaust note seems 'better' at 12 (vs. 8), more musical.
Needed more fuel >4500. Going by my past dyno graphs, I'm pretty sure the HP peak has inched closer to 320 rwhp. (SAE, Tom M.! )
From what I've been reading, later closing of the intake valve is what is making power here. Closing the exhaust valve ATDC may be helping too. The late closing of the intake valve effectively gives the cams more duration, which packs more air/fuel into the cylinders at high rpms. The late closing exhaust lets the exhaust pulse vacuum out the cylinder.
More duration lowers the 'high' S3/GT 10:1 static compression into the low nines (more?) reducing the effort required to compress the mixture, and allowing for much more ignition advance. More ignition advance masks the lower torque which would occur if only the valve timing were changed.
With -12° retard (crank° BTW), the S3 intake closes at a manly 62° ABDC, the exhaust at 7° ATDC.
(Valve timing, low vs. high speed engines)
(GT, GTS cams)
(GT, GTS cams)
